Using substitutions in a lamda function for a stepper motor control
I am trying to configure a stepper motor to run a certain number of steps determined by the value of an input_number.
But I also would like the input_number entity to be configurable with different entities in different configurations via substitutions.
here is the binary_sensor config in the common_nodemcu_stepper_motor.yaml:
binary_sensor:
  - platform: homeassistant
    #name: "Input Boolean From Home Assistant"
    entity_id: ${cycle_start}
    on_press:
      then:
        - stepper.report_position:
            position: 0
        - stepper.set_target:
            target: !lambda |-
              return (${cycle_steps}.state);
and here is the substitution:
substitutions:
  ip: 192.168.1.85
  ap: tank_feeder_ap
  friendly_name: Tank Feeder
  cycle_start: input_boolean.tank_feed_cycle_start
  cycle_steps: input_number.tank_feeder_step_counts # '150'
<<: !include common_nodemcu_stepper_motor.yaml
Any hints?
Have you verified the code without substitution first? cycle_start and cycle_steps shouldn’t include the device class (the period and the text before the period), for example:
  cycle_start: tank_feed_cycle_start
  cycle_steps: tank_feeder_step_counts # '150'
Because when you refer to a device in the lambda, it should be:
id(tank_feed_cycle_start)
so your lambda would be
return id(tank_feed_cycle_start).state;
or, with substitutions:
id($cycle_start)
and
return id($cycle_start).state;
I did a validation and everything checked ok.
But when it was compiling it threw an error:
I’ll see if i can decipher your suggestion :wink: and make changes.
Making the changes I suggested should resolve that.
binary_sensor:
    on_press:
      then:
            position: 0
            target: !lambda |-
              return (id(${cycle_steps}).state);
substitutions:
  ip: 192.168.1.85
  ap: tank_feeder_ap
How does esphome know which domain the entities are in HA? Does that have to be defined somewhere?
And thanks for your help on this.
and I just tried it with your code and it doesn’t validate:
You define the domain in your yaml. In your code you already posted you have defined that “tank_feed_start” is the ID for a binary_sensor device. ID’s are required to be unique. Elsewhere in your code I have assumed you’ve already defined what domain tank_feed_cycle_start and tank_feeder_step_counts are in.
Regarding being unique: In your code, try to create a duplicate ID by adding the code below and see what happens – you should get an error complaining about the ID being reused:
button:
Maybe I should just post the whole common file so we are on the same page:
esphome:
  platform: ESP8266
  board: esp01_1m
  board_flash_mode: dout
wifi:
  #hostname: ${name}
  networks:
    - ssid: "secret"
      password: !secret wifi_pwd
    - ssid: "secret too"
  reboot_timeout: 0s
  #fast_connect: true
  manual_ip:
    static_ip: ${ip}
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  ap:
    ssid: ${ap}
# Enable logging
logger:
# Enable Home Assistant API
api:
  #password: !secret esphome_api_pwd
  reboot_timeout: 0s
  services:
    - service: control_stepper
      variables:
        target: int
      then:
            id: ${id} # tank_feeder
            target: !lambda 'return target;'
ota:
stepper:
  - platform: uln2003
    id: ${id}  #tank_feeder
    pin_a: GPIO0 #D3
    pin_b: GPIO2 #D4
    pin_c: GPIO4 #D2
    pin_d: GPIO5 #D1
    max_speed: 100 steps/s
    # Optional:
    acceleration: inf
    deceleration: inf
binary_sensor:
    on_press:
      then:
            position: 0
            target: !lambda |-
switch:
  - platform: restart
text_sensor:
  - platform: version
    name: ${friendly_name} ESPHome Version
  - platform: wifi_signal
    name: ${friendly_name} WiFi Signal Strength
    update_interval: 60s
and the substitutions file:
substitutions:
  ip: 192.168.1.85
  ap: tank_feeder_ap
  # cycle_steps: input_number.tank_feeder_step_counts # '150'
  #cycle_start: tank_feed_cycle_start
and reading your post above I may be misunderstanding something else.
I want to set the start bit and the number of counts in HA. So in HA I created an input_boolean for the start cycle (input_boolean.tank_feed_cycle_start) and an input_number for the counts (input_number.tank_feeder_step_counts).
then I called those entities in my substitutions file and referenced them in the binary_sensor in the ESPHome yaml.
so cycle_start in ESPHome should equal the HA entity “input_boolean.tank_feed_cycle_start”
and cycle_steps in ESPHome should equal the HA entity “input_number.tank_feeder_step_counts”
is that not the correct way of doing that?
Sorry, I’m not understanding. The ESPHome docs are fairly vague.
OK I see what you are trying to do. You have to create a sensor within your ESP device that will take its state from an existing entity in Home Assistant. You can’t simply reference a home assistant entity anywhere in your ESP’s yaml code.
Home Assistant Sensor
So if you have created an input number entity in Home Assistant called input_number.tank_feed_cycle_start and you want your ESP to know about it, you have to have this in your code:
    entity_id: input_boolean.tank_feed_cycle_start
Then elsewhere in your yaml code when you want to refer to it, you’ll use the ID that was defined there: HA_tank_feed_start_input
Ok I think I get it now.
Would an input_boolean be a sensor or a binary_sensor?
I think the input_boolean should be a binary sensor and the input_number should be a sensor. Is that correct?
then I can use the id’s I create there in the stepper motor control?
Validation does not check lambdas.
That would explain that then.
So far I got the code to compile and flashed but I don’t have all of the hardware wired up yet. as soon as I do and it works as expected I’ll post the results here along with the full working code.
I think I’ll change the title to better reflect the full project instead of just the substitution aspect.
yes to everything, sounds like you’ve got it
it worked!
here is the full working code.
nodemcu_tank_feeder.yaml (for substitutions):
substitutions:
  ip: 192.168.1.85
  ap: tank_feeder_ap
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  networks:
    - ssid: "secret"
  reboot_timeout: 0s
  manual_ip:
    static_ip: ${ip}
  ap:
    ssid: ${ap}
# Enable logging
logger:
api:
  reboot_timeout: 0s
  services:
      variables:
        target: int
      then:
ota:
# 2048 steps per revolution of output shaft in full step mode
# 4096 steps per revolution of output shaft in half step mode
stepper:
  - platform: uln2003
    pin_a: GPIO0 #D3
    pin_b: GPIO2 #D4
    pin_c: GPIO4 #D2
    pin_d: GPIO5 #D1
    # Optional:
    acceleration: inf
    deceleration: inf
binary_sensor:
    on_press:
      then:
            position: 0
            target: !lambda |-
              return (id(feed_cycle_steps).state);
switch:
  - platform: restart
text_sensor:
  - platform: version
    entity_id: ${cycle_steps}
Now I’m going to use it to drive sweeper that will move a certain number of steps once a day that will discharge fish food into my aquarium for use when we go on vacation, etc.
Thanks again for your help.
Hello, thank you for this efforts and for sharing here your solution. I think it might be very helpful for the issue I’m currently facing in setting up a stepper motor based fertilizers dosing system, but I simply have no idea of what “substitutions” are, and this sensor inside a ESPHome device is something I’m also unfamiliar with. Maybe someone here can give me an hand?
Here is the code I currently have for my ESPHome device:
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
  services:
      variables:
        target: int
      then:
        - logger.log: "Speed updated"
stepper:
  - platform: uln2003
    sleep_when_done: true
    pin_a: D1
    pin_b: D2
    pin_c: D3
    pin_d: D4
    max_speed: 250 steps/s
ota:
  password: "xxxxxxxxxxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Stepper1 Fallback Hotspot"
    password: "xxxxxxxxxxxxxx"
captive_portal:
My configuration.yaml code for this:
# STEPPERS
input_number:
  stepper_control:
    initial: 0
    min: -1000
    max: 1000
    step: 1
    mode: slider
And my automations.yaml file got this:
- id: '1661897634736'
  alias: Control Stepper
    platform: state
    entity_id: input_number.stepper_control
  - service: esphome.stepper1
    data_template:
        target: "{{ trigger.to_state.state | int }}"
The current look of my dashboard:
Untitled
My final objective is to be able to control the amount (and direction) of steps I need a motor to perform, through an input number (instead of a finite and fiddly slider).
Also, it would be great to have a simple control with a start/stop button for non-automatized purposes.
From this, I think I have what I need to create the automatizations and expansions I will need for the whole project.
Thank you in advance for putting your time on this.
