Using Template and config-template-card to show tank level
I have a data feed that feeds the tanks filler percentage into a sensor value,
then use the below template to create a state.council_1_level_image
I then try and use the follow code on dashboard to try and show the image as per the above state…
needless to say not showing the image… if i replace the variable with actual path (/local/TankLevels0650) then image is shown.
Happy to share my tank images with anyone, they are at 2.5% increments.
Dashboard yaml
theme: Backend-selected
title: Water
path: water
badges: []
cards:
  - type: custom:flex-horseshoe-card
    entities:
      - entity: sensor.council_1_percent
        decimals: 0
        unit: "%"
      - entity: sensor.council_1_litre
        decimals: 1
        unit: L
      - entity: sensor.council_1_cm
        decimals: 2
        unit: cm
      - entity: sensor.council_1_last_update
    show:
      horseshoe_style: autominmax
    layout:
      hlines:
        - id: 0
          xpos: 50
          ypos: 40
          length: 70
          styles:
            - opacity: 0.2;
        - id: 0
          xpos: 50
          ypos: 60
          length: 70
          styles:
            - opacity: 0.2;
      vlines:
        - id: 0
          xpos: 50
          ypos: 50
          length: 18
          styles:
            - opacity: 0.2;
      states:
        - id: 0
          entity_index: 0
          xpos: 50
          ypos: 33
          styles:
            - font-size: 3em;
            - opacity: 0.9;
        - id: 1
          entity_index: 1
          xpos: 44
          ypos: 53
          styles:
            - font-size: 1.5em;
            - text-anchor: end;
        - id: 2
          entity_index: 2
          xpos: 55
          ypos: 53
          styles:
            - text-anchor: start;
            - font-size: 1.5em;
        - id: 3
          entity_index: 3
          xpos: 52
          ypos: 75
          styles:
            - font-size: 0.8em;
            - text-anchor: center;
      icons:
        - id: 0
          entity_index: 1
          xpos: 30
          ypos: 52
          align: start
      names:
        - id: 1
          entity_index: 0
          xpos: 50
          ypos: 95
          styles:
            - font-size: 1.2em;
        - id: 2
          entity_index: 0
          xpos: 85
          ypos: 12
          styles:
            - font-size: 0.5em;
    horseshoe_scale:
      min: 0
      max: 100
      width: 6
    color_stops:
      "10": "#FFF6E3"
      "20": "#FFE9B9"
      "30": "#FFDA8A"
      "40": "#FFCB5B"
      "50": "#FFBF37"
      "60": "#ffb414"
      "70": "#FFAD12"
      "80": "#FFA40E"
      "90": "#FF9C0B"
      "100": "#FF8C06"
    card_mod:
      style: |
        ha-card {
          --ha-card-background: var(--card-background-color);
          color: var(--primary-color);
  - type: vertical-stack
    cards:
      - type: glance
        entities:
      - type: custom:config-template-card
        entities:
          - sensor.council_1_level_image
        card:
          type: custom:hui-image-element
          entity: sensor.council_1_level_image
          image: "{{ states('sensor.council_1_level_image') }}"
        style:
          top: 45%
          left: 35%
          width: 5%
          height: 5%
          transform: translate(0%,2%)
    title: Council Tank
    entities:
      - entity: sensor.pot_1_percent
        decimals: 0
        unit: "%"
      - entity: sensor.pot_1_litre
        decimals: 1
        unit: L
      - entity: sensor.pot_1_cm
        decimals: 2
        unit: cm
      - entity: sensor.pot_1_last_update
    show:
    layout:
      hlines:
        - id: 0
          xpos: 50
          ypos: 40
          length: 70
          styles:
            - opacity: 0.2;
        - id: 0
          xpos: 50
          ypos: 60
          length: 70
          styles:
            - opacity: 0.2;
      vlines:
        - id: 0
          xpos: 50
          ypos: 50
          length: 18
          styles:
            - opacity: 0.2;
      states:
        - id: 0
          entity_index: 0
          xpos: 50
          ypos: 33
          styles:
            - font-size: 3em;
            - opacity: 0.9;
        - id: 1
          entity_index: 1
          xpos: 44
          ypos: 53
          styles:
            - font-size: 1.5em;
            - text-anchor: end;
        - id: 2
          entity_index: 2
          xpos: 55
          ypos: 53
          styles:
            - font-size: 1.5em;
        - id: 3
          entity_index: 3
          xpos: 52
          ypos: 75
          styles:
            - font-size: 0.8em;
      icons:
        - id: 0
          entity_index: 1
          xpos: 30
          ypos: 52
          align: start
      names:
        - id: 1
          entity_index: 0
          xpos: 50
          ypos: 95
          styles:
            - font-size: 1.2em;
        - id: 2
          entity_index: 0
          xpos: 85
          ypos: 12
          styles:
            - font-size: 0.5em;
    horseshoe_scale:
      min: 0
      max: 100
      width: 6
    color_stops:
      "10": "#FFF6E3"
      "20": "#FFE9B9"
      "30": "#FFDA8A"
      "40": "#FFCB5B"
      "50": "#FFBF37"
      "60": "#ffb414"
      "70": "#FFAD12"
      "80": "#FFA40E"
      "90": "#FF9C0B"
      "100": "#FF8C06"
    card_mod:
      style: |
        ha-card {
    cards:
      - type: glance
        entities:
        entities:
          - sensor.pot_1_level_image
        card:
          entity: sensor.pot_1_level_image
          image: "{{ states('sensor.pot_1_level_image') }}"
        style:
          top: 45%
          left: 35%
          width: 5%
          height: 5%
    title: Pot 1 Level
Template code
template:
  - sensor:
      - name: "Council 1 Level Image"
        state: >
          {% set input_value = states('sensor.council_1_percent') | float %}
          {% if 0 < input_value < 2.5 %}
            {{ "/local/TankLevels0000.jpg" }}
          {% elif 2.5 <= input_value < 5 %}
            {{ "/local/TankLevels0025.jpg" }}
          {% elif 5 <= input_value < 7.5 %}
            {{ "/local/TankLevels0050.jpg" }}
          {% elif 7.5 <= input_value < 10 %}
            {{ "/local/TankLevels0075.jpg" }}
          {% elif 10 <= input_value < 12.5 %}
            {{ "/local/TankLevels0100.jpg" }}
          {% elif 12.5 <= input_value < 15 %}
            {{ "/local/TankLevels0125.jpg" }}
          {% elif 15 <= input_value < 17.5 %}
            {{ "/local/TankLevels0150.jpg" }}
          {% elif 17.5 <= input_value < 20 %}
            {{ "/local/TankLevels0175.jpg" }}
          {% elif 20 <= input_value < 22.5 %}
            {{ "/local/TankLevels0200.jpg" }}
          {% elif 22.5 <= input_value < 25 %}
            {{ "/local/TankLevels0225.jpg" }}
          {% elif 25 <= input_value < 27.5 %}
            {{ "/local/TankLevels0250.jpg" }}
          {% elif 27.5 <= input_value < 30 %}
            {{ "/local/TankLevels0275.jpg" }}
          {% elif 30 <= input_value < 32.5 %}
            {{ "/local/TankLevels0300.jpg" }}
          {% elif 32.5 <= input_value < 35 %}
            {{ "/local/TankLevels0325.jpg" }}
          {% elif 35 <= input_value < 37.5 %}
            {{ "/local/TankLevels0350.jpg" }}
          {% elif 37.5 <= input_value < 40 %}
            {{ "/local/TankLevels0375.jpg" }}
          {% elif 40 <= input_value < 42.5 %}
            {{ "/local/TankLevels0400.jpg" }}
          {% elif 42.5 <= input_value < 45 %}
            {{ "/local/TankLevels0425.jpg" }}
          {% elif 45 <= input_value < 47.5 %}
            {{ "/local/TankLevels0450.jpg" }}
          {% elif 47.5 <= input_value < 50 %}
            {{ "/local/TankLevels0475.jpg" }}
          {% elif 50 <= input_value < 52.5 %}
            {{ "/local/TankLevels0500.jpg" }}
          {% elif 52.5 <= input_value < 55 %}
            {{ "/local/TankLevels0525.jpg" }}
          {% elif 55 <= input_value < 57.5 %}
            {{ "/local/TankLevels0550.jpg" }}
          {% elif 57.5 <= input_value < 60 %}
            {{ "/local/TankLevels0575.jpg" }}
          {% elif 60 <= input_value < 62.5 %}
            {{ "/local/TankLevels0600.jpg" }}
          {% elif 62.5 <= input_value < 65 %}
            {{ "/local/TankLevels0625.jpg" }}
          {% elif 65 <= input_value < 67.5 %}
            {{ "/local/TankLevels0650.jpg" }}
          {% elif 67.5 <= input_value < 70 %}
            {{ "/local/TankLevels0675.jpg" }}
          {% elif 70 <= input_value < 72.5 %}
            {{ "/local/TankLevels0700.jpg" }}
          {% elif 72.5 <= input_value < 75 %}
            {{ "/local/TankLevels0725.jpg" }}
          {% elif 75 <= input_value < 77.5 %}
            {{ "/local/TankLevels0750.jpg" }}
          {% elif 77.5 <= input_value < 80 %}
            {{ "/local/TankLevels0775.jpg" }}
          {% elif 80 <= input_value < 82.5 %}
            {{ "/local/TankLevels0800.jpg" }}
          {% elif 82.5 <= input_value < 85 %}
            {{ "/local/TankLevels0825.jpg" }}
          {% elif 85 <= input_value < 87.5 %}
            {{ "/local/TankLevels0850.jpg" }}
          {% elif 87.5 <= input_value < 90 %}
            {{ "/local/TankLevels0875.jpg" }}
          {% elif 90 <= input_value < 92.5 %}
            {{ "/local/TankLevels0900.jpg" }}
          {% elif 92.5 <= input_value < 95 %}
            {{ "/local/TankLevels0925.jpg" }}
          {% elif 95 <= input_value < 97.5 %}
            {{ "/local/TankLevels0950.jpg" }}
          {% elif 97.5 <= input_value <= 100 %}
            {{ "/local/TankLevels0975.jpg" }}
          {% else %}
            {{ "/local/TankLevels1000.jpg" }}
          {% endif %}
Anyone…
G
