Using template binary sensors in triggers
I have created a simple sun-based sensor
    sensors:
      is_light_outside:
        friendly_name: Is light outside
        value_template: "{{ state_attr('sun.sun', 'elevation')|float > -4 }}"
        device_class: illuminance
This works, but not in the way I expected. The documentation for template binary sensors says:
The state of a Template Binary Sensor can only be on or off .
The sensor is on if the template evaluates as True and off otherwise. The actual appearance in the frontend ( Open / Closed , Detected / Clear etc) depends on the sensor’s device_class value.
However, unlike all other binary sensors I’ve used, my template sensor’s value is actually True or False rather than on or off. In the developer tools:
and in the template viewer for {{ states('sensor.is_light_outside') }}:
So, none of these work (the expression is always false):
{{ is_state('sensor.is_light_outside', 'on') }}
{{ is_state('sensor.is_light_outside', True) }}
{{ is_state('sensor.is_light_outside', true) }}
{{ states('sensor.is_light_outside') == true }}
{{ states('sensor.is_light_outside') is true }}
Similarly, the sensor doesn’t work in a state trigger that checks for a specific value like 'on' or true.
Using the sensor directly as a boolean value in a template trigger does work, but it seems non-intuitive (because it doesn’t work like any other sensor):
So, I can use the sensor in a state trigger that triggers for any state change, or I can use the sensor in a template trigger as a boolean value, but not in the same way as a normal binary sensor. Is this the expected behavior for template binary sensors?
Where have you defined this sensor?
Is it a binary_sensor or a sensor?
Binary Sensor
binary_sensor:
    sensors:
      is_light_outside:
Sensor
    sensors:
      is_light_outside:
In configuration.yaml, and it’s a sensor, not a binary_sensor.
Hmmm…I would have sworn that the template binary sensor docs used sensor in the example, which I thought was particularly odd when I was creating the sensor. Apparently not. Let me just try that as a binary_sensor
If it’s a sensor then it’s reporting the correct state value (True/False).
If you define it as a binary_sensor then it will report on/off. However, illuminance is not a valid device_class for a binary_sensor. You’ll have to choose something else.
I actually had the device class as light at first, but of course that didn’t work since I had defined the sensor as a sensor rather than binary_sensor.
Yay, that works much better. Chalk this up to me not being able to read the docs late at night. :grin:
