SamB
April 8, 2019, 6:26am
1
I am trying to write an automation that will dim any lights which are turned on, but not act on any that are off:
- alias: Dim Lights in Evening
platform: sun
event: sunset
offset: "01:00:00"
condition:
condition: state
entity_id: input_boolean.automate_lighting
state: 'on'
- service: light.turn_on
data_template:
entity_id: >
[{%- for light in states.light -%}
{%- if light.state == 'on' -%}
{{ light.entity_id }},
{%- endif -%}
{%- endfor -%}]
color_temp: 443
brightness: 144
If I evaluate the template in the Template Editor and paste the output in place of the entity_id template, the automation works as desired.
However if I use the template to generate the entity_id list, the following error is printed to the log:
Invalid data for call_service at pos 1: not a valid value for dictionary value @ data['entity_id']
I have tried every variation I can think of based on the templating docs and other posts here, but cannot get it to work.
If anybody can tell me the correct way to do this it would be greatly appreciated
jparthum
(Jason Parthum)
April 8, 2019, 8:00am
2
Try removing the square brackets []
platform: sun
event: sunset
offset: "01:00:00"
condition:
condition: state
state: 'on'
data_template:
entity_id: >
{%- endif -%}
{%- endfor -%}
color_temp: 443
brightness: 144
Here is maybe an easier way (and also handles the case where none of the lights are on):
platform: sun
event: sunset
offset: "01:00:00"
condition:
- condition: state
state: 'on'
- condition: template
value_template: >
{{ states.light|selectattr('state','eq','on')|list|count > 0 }}
data_template:
entity_id: >
|map(attribute='entity_id')|join(',') }}
color_temp: 443
brightness: 144
pnbruckner:
condition: template value_template: > {{ states.light|selectattr(‘state’,‘eq’,‘on’)|list|count > 0 }}
coincidentally busy with a related issue, I thought to use:
value_template: >
{{state_attr('group.lights','on')}}
If any of the lights is on (your count >0) the group would be on? Change the group name of course.
Yes, that could work, too. In this case I’d just use group.all_lights
which is automatically maintained.
yes that would be easiest and default. I mostly use a group.all_lights_only, which is hand made and maintained, because the group.all_lights also contains Hue groups, which are imported as light…Other advantage of the group usage is one can leave out several lights, that should always be exempt of any automation. Think of outside lights in this case, which are on at night but needn’t be dimmed by the automation.
123
(Taras)
April 9, 2019, 1:35pm
7
I don’t understand how that template is supposed to work. It’s looking for an attribute named on
in group.lights
If I replace it with group.all_lights
it produces the following results:
As expected, is_state
produces a valid result but not state_attr
(when defined that way).
What am I missing here?
Nothing. It should be is_state
; I just looked right past that. lol! I’m sure that’s what @Mariusthvdb meant.
123
(Taras)
April 9, 2019, 3:03pm
9
Well OK then! So you Jinja-ninjas are mortal after all!
I am so sorry… should have been:
{{is_state('group.all_inside_lights','on')}}
as you can see, no lights on inside, but the group all_lights (or states.light in this template) has a light.outdoors on. Which is a Hue group (room).
sorry for my mistake. glad you noticed @123
SamB
April 10, 2019, 8:30pm
11
Thanks @pnbruckner , that is much tidier and works exactly as desired!
Lipown
(Lipown)
January 6, 2020, 2:45pm
12
Supposing you have the more rooms and in each room more lights that you want to control by the remote that each room has its own, how would you change the data template for each group?
Sorry, I’m not quite sure what you’re asking. Can you explain a bit more about what you want?
