Sure, here’s a simple example for controlling my Sonos media player:
[{"id":"74838286f6d294a1","type":"function","z":"363b155f867f60a4","name":"Philips Tap Dial","func":"var command = msg.payload.event.command;\nvar step_mode = msg.payload.event.params.step_mode;\nvar step_size = msg.payload.event.params.step_size;\nvar device = msg.payload.event.device_ieee;\nvar scene_id = msg.payload.event.params.scene_id\n\n// Match specific device\nif (device == \"00:17:99:01:d0:35:21:f0\") {\n\n// Decode wheel\n if (command == \"step_with_on_off\") {\n\n msg.step_size = step_size;\n\n if (step_mode == 0) {\n msg.payload = \"wheel_right\";\n return [msg];\n }\n if (step_mode == 1) {\n msg.payload = \"wheel_left\";\n return [msg];\n }\n }\n\n// Decode buttons\n if (command == \"recall\") {\n if (scene_id == 1) {\n msg.payload = \"button_1\";\n return [msg];\n }\n if (scene_id == 0) {\n msg.payload = \"button_2\";\n return [msg];\n }\n if (scene_id == 5) {\n msg.payload = \"button_3\";\n return [msg];\n }\n if (scene_id == 4) {\n msg.payload = \"button_4\";\n return [msg];\n }\n }\n\n// Ignore anything else\n msg.payload = \"unknown\";\n return [msg];\n}\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":420,"y":340,"wires":[["959bccac696fa856"]]},{"id":"959bccac696fa856","type":"switch","z":"363b155f867f60a4","name":"Route on Keys","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"wheel_right","vt":"str"},{"t":"eq","v":"wheel_left","vt":"str"},{"t":"eq","v":"button_1","vt":"str"},{"t":"eq","v":"button_2","vt":"str"},{"t":"eq","v":"button_3","vt":"str"},{"t":"eq","v":"button_4","vt":"str"}],"checkall":"false","repair":false,"outputs":6,"x":640,"y":340,"wires":[["402a11688139dc6f"],["aabf4a0182959ad3"],["f44563f2dca0386b"],["398ee6fa56d803d3","14f88ed8c1f6d347"],["94d9d1c768419941","14f88ed8c1f6d347"],["081aca748b7d9720","14f88ed8c1f6d347"]],"info":"Decode all keys.\r\nLast option (!= unknown) is used to turn system option\r\nregardless of which key is pressed."},{"id":"6d92c191ab4c491a","type":"server-events","z":"363b155f867f60a4","name":"ZHA Events","server":"","version":2,"eventType":"zha_event","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"},{"property":"event_type","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"}],"x":210,"y":340,"wires":[["74838286f6d294a1"]]},{"id":"402a11688139dc6f","type":"smooth","z":"363b155f867f60a4","name":"Smooth Wheel","property":"step_size","action":"mean","count":"5","round":"","mult":"single","reduce":false,"x":900,"y":180,"wires":[["c5d456a0261f9415"]]},{"id":"c5d456a0261f9415","type":"switch","z":"363b155f867f60a4","name":"Rate","property":"step_size","propertyType":"msg","rules":[{"t":"btwn","v":"1","vt":"num","v2":"28","v2t":"num"},{"t":"gte","v":"29","vt":"num"}],"checkall":"false","repair":false,"outputs":2,"x":1110,"y":180,"wires":[["bfd395bf8ba90f68"],["7d176a16a10f2bbf"]]},{"id":"bfd395bf8ba90f68","type":"trigger","z":"363b155f867f60a4","name":"Turbo","op1":"1","op2":"1","op1type":"str","op2type":"str","duration":"150","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1310,"y":140,"wires":[["7d176a16a10f2bbf"]]},{"id":"5d029d886f41cfbb","type":"switch","z":"363b155f867f60a4","name":"Rate","property":"step_size","propertyType":"msg","rules":[{"t":"btwn","v":"0","vt":"num","v2":"28","v2t":"num"},{"t":"gte","v":"29","vt":"num"}],"checkall":"false","repair":false,"outputs":2,"x":1110,"y":240,"wires":[["8e8be3d75ae8c5ad"],["6e85b26c95bde590"]]},{"id":"8e8be3d75ae8c5ad","type":"trigger","z":"363b155f867f60a4","name":"Turbo","op1":"1","op2":"1","op1type":"str","op2type":"str","duration":"150","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1310,"y":220,"wires":[["6e85b26c95bde590"]]},{"id":"aabf4a0182959ad3","type":"smooth","z":"363b155f867f60a4","name":"Smooth Wheel","property":"step_size","action":"mean","count":"5","round":"","mult":"single","reduce":false,"x":900,"y":240,"wires":[["5d029d886f41cfbb"]]},{"id":"7d176a16a10f2bbf","type":"api-call-service","z":"363b155f867f60a4","name":"Volume Up","server":"","version":5,"debugenabled":false,"domain":"media_player","service":"volume_up","areaId":[],"deviceId":["3e162fec8a7f41cd9fadaa9c8683ee4b"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1530,"y":160,"wires":[[]]},{"id":"6e85b26c95bde590","type":"api-call-service","z":"363b155f867f60a4","name":"Volume Down","server":"","version":5,"debugenabled":false,"domain":"media_player","service":"volume_down","areaId":[],"deviceId":["3e162fec8a7f41cd9fadaa9c8683ee4b"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1540,"y":240,"wires":[[]]},{"id":"52da02ce07399143","type":"api-call-service","z":"363b155f867f60a4","name":"Next Track","server":"","version":5,"debugenabled":false,"domain":"media_player","service":"media_next_track","areaId":[],"deviceId":["3e162fec8a7f41cd9fadaa9c8683ee4b"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1130,"y":440,"wires":[[]]},{"id":"7b9b8d76ab95f84d","type":"api-call-service","z":"363b155f867f60a4","name":"Previous Track","server":"","version":5,"debugenabled":false,"domain":"media_player","service":"media_previous_track","areaId":[],"deviceId":["3e162fec8a7f41cd9fadaa9c8683ee4b"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1140,"y":500,"wires":[[]]},{"id":"f44563f2dca0386b","type":"api-call-service","z":"363b155f867f60a4","name":"Sonos Play/Pause","server":"","version":5,"debugenabled":false,"domain":"media_player","service":"media_play_pause","areaId":[],"deviceId":["3e162fec8a7f41cd9fadaa9c8683ee4b"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1150,"y":320,"wires":[[]]},{"id":"bed4d7451f47a1e5","type":"comment","z":"363b155f867f60a4","name":"Sonos - Philips Tapdial Remote","info":"Use this remote to control main floor Sonos.","x":250,"y":240,"wires":[]},{"id":"8ead401db89f55dc","type":"switch","z":"363b155f867f60a4","name":"Toggle Pergola","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1140,"y":560,"wires":[[]]},{"id":"398ee6fa56d803d3","type":"timed-counter","z":"363b155f867f60a4","name":"Double Click?","timelimit":350,"timeunit":1,"withhold":true,"fixedtimeout":true,"pertopic":false,"x":900,"y":440,"wires":[["52da02ce07399143"]]},{"id":"94d9d1c768419941","type":"timed-counter","z":"363b155f867f60a4","name":"Double Click?","timelimit":350,"timeunit":1,"withhold":true,"fixedtimeout":true,"pertopic":false,"x":900,"y":500,"wires":[["7b9b8d76ab95f84d"]]},{"id":"081aca748b7d9720","type":"timed-counter","z":"363b155f867f60a4","name":"Double Click?","timelimit":350,"timeunit":1,"withhold":true,"fixedtimeout":true,"pertopic":false,"x":900,"y":560,"wires":[["8ead401db89f55dc"]]},{"id":"14f88ed8c1f6d347","type":"api-current-state","z":"363b155f867f60a4","name":"Sonos Idle?","server":"","version":3,"outputs":2,"halt_if":"idle","halt_if_type":"str","halt_if_compare":"is","entity_id":"media_player.living_room","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":890,"y":380,"wires":[["f44563f2dca0386b"],[]],"info":"Let any key start Sonos playing"}]
You would need to change the MAC address in the function node to match your Tapdial, and obviously the service calls to match your devices, but it gives you the general idea.
