Using the Ring Alarm Keypad with Home Assistant
Change volume of the alarm panel verbal alerts/messages? – is there a way to change the volume of the verbal messages such as when the panel says “alarm armed” or “alarm disarmed”?
I have a panel in my bedroom. An automation turns the alarm on at 11pm. The “alarm armed” message sometimes wakes me up.
Thanks!
This is what I use:
alias: Ring Keypad Hal Volume 23u-7u
description: ""
  - platform: time
    at: "23:00:00"
  - platform: time
    at: "07:00:00"
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: zwave_js.set_config_parameter
              parameter: "4"
              value: "7"
              device_id: 9dc75032ebd0c9aa1b53afb2a2e98c85
      - conditions:
        sequence:
              parameter: "4"
              value: "3"
mode: single
You need to change device_id to your keypad off course. If you paste this in an automation, you can switch to visual edit mode, that might be easier to adapt it to your situation.
Thank you! I’m giving that a try now. I see that Parameter 4 is the Announcement Audio Volume which has a default value of 7. At 11pm, it goes down to a value of 3. Should work. Thanks a bunch!
I have one keypad working flawlessly, and I am wanting to add a second one, how did you add the second one, have you just duplicated the automation from the blueprint, or have you modified the automation to accept both keypads? If so, how…?
Just create another automation from the blueprint, pointing it at your alarm and your second keypad. I have two working with no issues.
@ImSorryButWho
Much appreciated.
Thanks for the quick reply…
I also bought the keypad and the ZST39 LR (800 Series) and installed z-wave js as explained here. Via the HA-Z-Wave Ui I inserted the value of the QR code of the keypad (SmartStart). The message appears: “The device has been added. Once you power it on, it will become available.”
Unfortunately, nothing happens after restarting the keypad or resetting (back of the device with a pin).
The keypad is located two meters from the dongle for testing.
What else can I try? Thank you!
Edit: Here is the log-File from Z-Wave JS after rebooting HA and inserting the QR-Code Value again:
· FUNC_ID_ZW_GET_VIRTUAL_NODES (0xa5)
                                    · FUNC_ID_ZW_IS_VIRTUAL_NODE (0xa6)
                                    · BridgeApplicationCommand (0xa8)
                                    · SendDataBridge (0xa9)
                                    · SendDataMulticastBridge (0xab)
                                    · UNKNOWN_FUNC_GET_LIBRARY_TYPE (0xbd)
                                    · UNKNOWN_FUNC_SEND_TEST_FRAME (0xbe)
                                    · UNKNOWN_FUNC_GET_PROTOCOL_STATUS (0xbf)
                                    · UNKNOWN_FUNC_UNKNOWN_0xD2 (0xd2)
                                    · UNKNOWN_FUNC_UNKNOWN_0xD3 (0xd3)
                                    · UNKNOWN_FUNC_UNKNOWN_0xD4 (0xd4)
                                    · undefined (0xd6)
                                    · undefined (0xd7)
                                    · undefined (0xd8)
                                    · Shutdown (0xd9)
                                    · undefined (0xda)
                                    · undefined (0xdb)
                                    · undefined (0xdc)
                                    · undefined (0xdd)
                                    · undefined (0xde)
                                    · undefined (0xdf)
                                    · undefined (0xe7)
                                    · undefined (0xe8)
2023-08-22T09:41:37.149Z CNTRLR   querying serial API setup capabilities...
2023-08-22T09:41:37.183Z CNTRLR   supported serial API setup commands:
                                  · Unsupported
                                  · GetSupportedCommands
                                  · SetTxStatusReport
                                  · SetLRMaximumTxPower
                                  · SetPowerlevel
                                  · unknown (0x07)
                                  · unknown (0x0f)
                                  · GetMaximumPayloadSize
                                  · GetLRMaximumPayloadSize
                                  · SetPowerlevel16Bit
                                  · unknown (0x1f)
                                  · unknown (0x3f)
                                  · unknown (0x7f)
2023-08-22T09:41:37.186Z CNTRLR   querying controller IDs...
2023-08-22T09:41:37.211Z CNTRLR   received controller IDs:
                                    home ID:     0xfcf38137
                                    own node ID: 1
2023-08-22T09:41:37.256Z CNTRLR   Performing soft reset...
2023-08-22T09:41:37.488Z DRIVER     no handlers registered!
2023-08-22T09:41:38.270Z CNTRLR   Failed to execute controller command after 1/3 attempts. Scheduling next try i
                                  n 100 ms.
2023-08-22T09:41:38.598Z DRIVER     no handlers registered!
2023-08-22T09:41:39.378Z CNTRLR   Failed to execute controller command after 2/3 attempts. Scheduling next try i
                                  n 1100 ms.
2023-08-22T09:41:40.705Z DRIVER     no handlers registered!
2023-08-22T09:41:41.491Z CNTRLR   Soft reset failed: Timeout while waiting for an ACK from the controller (ZW020
                                  0)
2023-08-22T09:41:41.495Z CNTRLR   Waiting for the controller to reconnect...
2023-08-22T09:41:42.997Z CNTRLR   Waiting for the Serial API to start...
2023-08-22T09:41:48.000Z CNTRLR   Did not receive notification that Serial API has started, checking if it respo
                                  nds...
2023-08-22T09:41:48.047Z CNTRLR   Serial API responded
2023-08-22T09:41:48.069Z CNTRLR   supported Z-Wave features:
                                    · SmartStart
2023-08-22T09:41:48.069Z CNTRLR   querying controller capabilities...
2023-08-22T09:41:48.088Z CNTRLR   received controller capabilities:
                                    controller role:      primary
                                    is the SUC:           true
                                    started this network: true
                                    SIS is present:       true
                                    was real primary:     true
2023-08-22T09:41:48.089Z CNTRLR   Enabling TX status report...
2023-08-22T09:41:48.108Z CNTRLR   Enabling TX status report successful...
2023-08-22T09:41:48.109Z CNTRLR   finding SUC...
2023-08-22T09:41:48.130Z CNTRLR   This is the SUC
2023-08-22T09:41:48.131Z CNTRLR   querying additional controller information...
2023-08-22T09:41:48.151Z CNTRLR   received additional controller information:
                                    Z-Wave API version:         1 (official)
                                    Z-Wave chip type:           EFR32ZG23 / ZGM230S
                                    node type                   Controller
                                    controller is the SIS:      true
                                    controller supports timers: false
                                    nodes in the network:       1
2023-08-22T09:41:48.192Z CNTRLR   [Node 001] Embedded device config loaded
2023-08-22T09:41:48.217Z CNTRLR   Interview completed
2023-08-22T09:41:48.221Z CNTRLR   Enabling Smart Start listening mode...
Starting server on 0.0.0.0:3000
2023-08-22T09:41:48.264Z CNTRLR   [Node 001] The node is alive.
2023-08-22T09:41:48.266Z CNTRLR   [Node 001] The node is ready to be used
2023-08-22T09:41:48.268Z CNTRLR   All nodes are ready to be used
ZwaveJS server listening on 0.0.0.0:3000
2023-08-22T09:41:48.288Z CNTRLR   Smart Start listening mode enabled
New client
New client
Client disconnected
Code 1000:
2023-08-22T10:03:17.283Z CNTRLR   Leaving Smart Start listening mode...
2023-08-22T10:03:17.303Z CNTRLR   Left Smart Start listening mode
2023-08-22T10:03:17.304Z CNTRLR   Starting inclusion process with strategy Default...
2023-08-22T10:03:17.320Z CNTRLR   The controller is now ready to add nodes
2023-08-22T10:03:18.773Z CNTRLR   stopping inclusion process...
2023-08-22T10:03:18.795Z CNTRLR   The inclusion process was stopped
2023-08-22T10:03:18.797Z CNTRLR   Enabling Smart Start listening mode...
2023-08-22T10:03:18.808Z CNTRLR   Smart Start listening mode enabled
Debugging Smart Start is definitely frustrating, and I’m afraid I don’t have any great advice. The first thing I’d try is moving the keypad closer when it first started up. That’s not great advice in general, but this keypad has a long interview that’s very sensitive to dropped frames. If that doesn’t work, try the classic inclusion process detailed on the GitHub. Just be sure you have the pin ready to go, since it will time out the S2 negotiation quickly.
Thank you for your help!
Using the Z-Wave JS Supervisor add-on is correct, isn´t it?
Either should work, although ZwaveJS UI makes it a bit easier to see what’s going on and troubleshoot problems.
Thank you!
Z-Wave JS Logs are not very helpful for me:
Subscribed to Z-Wave JS Log Messages…
2023-08-23T08:56:57.554Z CNTRLR   Leaving Smart Start listening mode...
2023-08-23T08:56:57.560Z DRIVER   all queues busy
2023-08-23T08:56:57.567Z DRIVER » [REQ] [AddNodeToNetwork]
                                    action:       Stop
                                    high power:   true
                                    network wide: true
                                    callback id:  0
2023-08-23T08:56:57.575Z CNTRLR   Left Smart Start listening mode
2023-08-23T08:56:57.576Z CNTRLR   Starting inclusion process with strategy Default...
2023-08-23T08:56:57.584Z DRIVER » [REQ] [AddNodeToNetwork]
                                    node type:    Any
                                    high power:   true
                                    network wide: true
                                    callback id:  13
2023-08-23T08:56:57.591Z DRIVER « [REQ] [AddNodeToNetwork]
                                    status:      Ready
                                    callback id: 13
2023-08-23T08:56:57.595Z CNTRLR   The controller is now ready to add nodes
2023-08-23T08:56:57.597Z DRIVER   all queues idle
2023-08-23T08:57:03.709Z DRIVER   all queues busy
2023-08-23T08:57:03.713Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-08-23T08:57:03.720Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -85 dBm
                                    channel 1: -88 dBm
                                    channel 2: -88 dBm
2023-08-23T08:57:03.728Z DRIVER   all queues idle
2023-08-23T08:57:33.712Z DRIVER   all queues busy
2023-08-23T08:57:33.722Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-08-23T08:57:33.730Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -86 dBm
                                    channel 1: -88 dBm
                                    channel 2: -88 dBm
2023-08-23T08:57:33.735Z DRIVER   all queues idle
2023-08-23T08:58:03.711Z DRIVER   all queues busy
2023-08-23T08:58:03.720Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-08-23T08:58:03.727Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -86 dBm
                                    channel 1: -88 dBm
                                    channel 2: -88 dBm
2023-08-23T08:58:03.736Z DRIVER   all queues idle
2023-08-23T08:58:27.541Z CNTRLR   stopping inclusion process...
2023-08-23T08:58:27.549Z DRIVER   all queues busy
2023-08-23T08:58:27.557Z DRIVER » [REQ] [AddNodeToNetwork]
                                    action:       Stop
                                    high power:   true
                                    network wide: true
                                    callback id:  14
2023-08-23T08:58:27.566Z DRIVER « [REQ] [AddNodeToNetwork]
                                    status:      Done
                                    callback id: 14
2023-08-23T08:58:27.570Z CNTRLR   The inclusion process was stopped
2023-08-23T08:58:27.572Z CNTRLR   Enabling Smart Start listening mode...
2023-08-23T08:58:27.579Z DRIVER » [REQ] [AddNodeToNetwork]
                                    action: Enable Smart Start listening mode
2023-08-23T08:58:27.584Z CNTRLR   Smart Start listening mode enabled
2023-08-23T08:58:27.586Z DRIVER   all queues idle
2023-08-23T08:58:33.713Z DRIVER   all queues busy
2023-08-23T08:58:33.723Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-08-23T08:58:33.734Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -85 dBm
                                    channel 1: -88 dBm
                                    channel 2: -88 dBm
2023-08-23T08:58:33.738Z DRIVER   all queues idle
2023-08-23T08:59:03.713Z DRIVER   all queues busy
2023-08-23T08:59:03.724Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-08-23T08:59:03.733Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -86 dBm
                                    channel 1: -88 dBm
                                    channel 2: -88 dBm
2023-08-23T08:59:03.738Z DRIVER   all queues idle
2023-08-23T08:59:33.712Z DRIVER   all queues busy
2023-08-23T08:59:33.720Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-08-23T08:59:33.727Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -85 dBm
                                    channel 1: -88 dBm
                                    channel 2: -88 dBm
2023-08-23T08:59:33.731Z DRIVER   all queues idle
2023-08-23T09:00:03.712Z DRIVER   all queues busy
2023-08-23T09:00:03.719Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-08-23T09:00:03.727Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -85 dBm
                                    channel 1: -88 dBm
                                    channel 2: -88 dBm
2023-08-23T09:00:03.733Z DRIVER   all queues idle
2023-08-23T09:00:19.532Z CNTRLR   Leaving Smart Start listening mode...
2023-08-23T09:00:19.540Z DRIVER   all queues busy
2023-08-23T09:00:19.544Z DRIVER » [REQ] [AddNodeToNetwork]
                                    action:       Stop
                                    high power:   true
                                    network wide: true
                                    callback id:  0
2023-08-23T09:00:19.552Z CNTRLR   Left Smart Start listening mode
2023-08-23T09:00:19.553Z CNTRLR   Starting inclusion process with strategy Default...
2023-08-23T09:00:19.559Z DRIVER » [REQ] [AddNodeToNetwork]
                                    node type:    Any
                                    high power:   true
                                    network wide: true
                                    callback id:  15
2023-08-23T09:00:19.566Z DRIVER « [REQ] [AddNodeToNetwork]
                                    status:      Ready
                                    callback id: 15
2023-08-23T09:00:19.569Z CNTRLR   The controller is now ready to add nodes
2023-08-23T09:00:19.571Z DRIVER   all queues idle
Did I buy the wrong keypad? Model: 5B28S8
I tried it 100 of times, but ha doesn´t see the keypad.
Is something wrong with my Z-Wave JS Config?
It looks like you’re trying to use classic inclusion mode, which is a good idea if smart start isn’t working. When you put the stick into inclusion mode, are you holding down the 1 button on the keypad to start classic inclusion?
It’s also a good idea to explicitly exclude a device, not factory reset it.
Try the following, and collect logs while you do it:
  • Put the stick into exclusion mode. On the Zwave page, “remove a device”
  • Tap (don’t hold) the rest button with a pin.
  • Wait for things to settle.
  • Put the stick into inclusion mode (“add a device”)
  • Hold down 1 on the keypad until it starts blinking green
Thank you for your help.
I send you a video where you can see my steps. In the log I can´t find any helpful information.
                                    · SetPriorityRoute (0x93)
                                    · UNKNOWN_FUNC_UNKNOWN_0x98 (0x98)
                                    · FUNC_ID_SERIAL_API_SLAVE_NODE_INFO (0xa0)
                                    · FUNC_ID_ZW_SEND_SLAVE_NODE_INFO (0xa2)
                                    · FUNC_ID_ZW_SET_SLAVE_LEARN_MODE (0xa4)
                                    · undefined (0xd6)
                                    · undefined (0xd7)
                                    · undefined (0xd8)
                                    · Shutdown (0xd9)
                                    · undefined (0xda)
                                    · undefined (0xdb)
                                    · undefined (0xdc)
                                    · undefined (0xdd)
                                    · undefined (0xde)
                                    · undefined (0xdf)
                                    · undefined (0xe7)
                                    · undefined (0xe8)
2023-08-24T11:25:17.024Z CNTRLR   querying serial API setup capabilities...
2023-08-24T11:25:17.054Z CNTRLR   supported serial API setup commands:
                                  · Unsupported
                                  · SetTxStatusReport
                                  · SetPowerlevel
                                  · unknown (0x07)
                                  · unknown (0x0f)
                                  · unknown (0x1f)
                                  · unknown (0x3f)
                                  · unknown (0x7f)
2023-08-24T11:25:17.057Z CNTRLR   querying controller IDs...
2023-08-24T11:25:17.077Z CNTRLR   received controller IDs:
                                    home ID:     0xfcf38137
                                    own node ID: 1
2023-08-24T11:25:17.107Z CNTRLR   Performing soft reset...
2023-08-24T11:25:17.122Z CNTRLR   Waiting for the controller to reconnect...
2023-08-24T11:25:17.344Z CNTRLR   reconnected and restarted
2023-08-24T11:25:17.365Z CNTRLR   supported Z-Wave features:
                                    · SmartStart
2023-08-24T11:25:17.365Z CNTRLR   querying controller capabilities...
2023-08-24T11:25:17.383Z CNTRLR   received controller capabilities:
                                    is the SUC:           true
2023-08-24T11:25:17.383Z CNTRLR   Enabling TX status report...
2023-08-24T11:25:17.432Z CNTRLR   Enabling TX status report successful...
2023-08-24T11:25:17.433Z CNTRLR   finding SUC...
2023-08-24T11:25:17.449Z CNTRLR   This is the SUC
2023-08-24T11:25:17.450Z CNTRLR   querying additional controller information...
2023-08-24T11:25:17.472Z CNTRLR   received additional controller information:
2023-08-24T11:25:17.510Z CNTRLR   [Node 001] Embedded device config loaded
2023-08-24T11:25:17.531Z CNTRLR   Interview completed
2023-08-24T11:25:17.535Z CNTRLR   Enabling Smart Start listening mode...
2023-08-24T11:25:17.571Z CNTRLR   [Node 001] The node is alive.
2023-08-24T11:25:17.573Z CNTRLR   [Node 001] The node is ready to be used
2023-08-24T11:25:17.574Z CNTRLR   All nodes are ready to be used
2023-08-24T11:25:17.590Z CNTRLR   Smart Start listening mode enabled
New client
2023-08-24T11:53:25.710Z CNTRLR   Leaving Smart Start listening mode...
2023-08-24T11:53:25.730Z CNTRLR   Left Smart Start listening mode
2023-08-24T11:53:25.730Z CNTRLR   starting exclusion process...
2023-08-24T11:53:25.749Z CNTRLR   The controller is now ready to remove nodes
2023-08-24T11:54:04.275Z CNTRLR   stopping exclusion process...
2023-08-24T11:54:04.297Z CNTRLR   the exclusion process was stopped
2023-08-24T11:54:04.298Z CNTRLR   Enabling Smart Start listening mode...
2023-08-24T11:54:04.309Z CNTRLR   Smart Start listening mode enabled
2023-08-24T11:54:06.907Z CNTRLR   Leaving Smart Start listening mode...
2023-08-24T11:54:06.920Z CNTRLR   Left Smart Start listening mode
2023-08-24T11:54:06.921Z CNTRLR   Starting inclusion process with strategy Default...
2023-08-24T11:54:06.939Z CNTRLR   The controller is now ready to add nodes
2023-08-24T11:55:11.989Z CNTRLR   stopping inclusion process...
2023-08-24T11:55:12.012Z CNTRLR   The inclusion process was stopped
2023-08-24T11:55:12.014Z CNTRLR   Enabling Smart Start listening mode...
2023-08-24T11:55:12.024Z CNTRLR   Smart Start listening mode enabled
Starting logging event forwarder at info level
Stopping logging event forwarder
I repeated the steps many times and pressed the button on the ring pad for a short/long time, unplugged and plugged in the device, restarted HA,… Unfortunately, I don’t see a ring pad in the log.
thanks for the nice integration with alarmo.
the keypad is working fine, i only have one issue.
number 1,3,7,9 are flashing white the whole time , any idea how to stop this?
it’s there away to update the firmware
I have downloaded the latest blueprint for Alarmo. The communication between Alarmo and the Ring Keypad V2 should work as I receive all the information of the security system state on the keypad (controlling the system via phone). The only issue I have is that I can not arm the security system via the keypad directly. I am inserting the code and then press „armed away“ button, but I receive only a fault signal sound. I have also traced the z-wave events and it seems the correct code is transmitted in the event_data field, but after I have pressed “armed away” the event_data is set to “null” and again I receive this fault sound.
I hope you could help me.
Thanks and best regards,
M4v3
You’re seeing the code and arm away press in separate events? Is your code unusually long?
Make sure the key cache size (under there entry control CC section of the node in ZwaveJSUI) is larger than the length of your code.
Hi ImSorryButWho,
thank you for your reply.
Yes, I see two different events.
I am using a 8-digit number - where can I find this entry control CC section of the node in ZwaveJSUI?
Thx
BR
Hello People,
I am attempting to use a Ring Alarm Keypad to unlock a lock. I’ve noticed that I can initiate an automation triggered by the ‘Enter’ event of the Keypad.
My question is, how can I utilize the following inputs:
  domain: zwave_js
  node_id: 4
  home_id: xxxxxxxx
  endpoint: 0
  device_id: xxxxxxxxxxxxxxxxxxx
  command_class: 111
  command_class_name: Entry Control
  event_type: 2
  event_type_label: Enter
  data_type: 2
  data_type_label: ASCII
  event_data: "5555"
origin: LOCAL
time_fired: "2023-11-14T19:43:06.026274+00:00"
I want to trigger the automation with the event above and then compare the event_data with the values of another entity property (Rental Control Integration entity: Slot code). Additionally, I want to check if the time_fired is within a specified range of values from another set of data (Rental Control Integration entity: start, end).
Logically, it’s a straightforward task, but I don’t have any experience with YAML automations in Home Assistant. ---- I don’t have any experience with YAML anywhere :wink:
Regards,
Listening to any events, I do for example not see any event sent when the delay period is over after countdown on 18 (Exit delay). Not sure how to manage this in a good way?
