Is it possible to use this graph
With another entity? I have a Sonoff S31 with energy meter.
“above horizon” should be when the plug is ON and “below horizon” should be when the plug is OFF / zero watts
How can I do this?
Thanks!
How can I do this?
Thanks!
The history graph will display like that when the entity has no unit_of_measurement
. Since switches don’t have a unit of measurement all you have to do is add it to a history graph.
type: history-graph
entities:
- entity: switch.your_sonoff_switch_here
hours_to_show: 24
refresh_interval: 0
Thank you! It was easier than I thought. I had already tried the history-graph with the sonoff entity, my mistake is I was using a sensor entity and I had to use the switch entity.
