Suuuper quick question which I am unable to find the answer for it:
I have a input_number
variable that contains an integer which is set by another automation (which works). It contains the Temperature required for the leaving water temperature of the heatpump.
I can set this only as an action → device (not service) as such:
- device_id: 67472ecafa2092a1b9d0ef6f38173dfe
domain: number
entity_id: number.temperature_control
type: set_value
value: 38
Now this is static for 38. I want the 38 to be whatever input_number.daikin_ufh_lwt
is:
domain: number
type: set_value
data_template:
value: >-
{{ states("input_number.daikin_ufh_lwt") | float }}
yields Message malformed: extra keys not allowed @ data['data_template']
, while doing a
domain: number
type: set_value
value: >
yields a Message malformed: expected float for dictionary value @ data['value']
The heat curve is perfect. I just need to punch that number in… *But How?
