The update for Orbot came out this weekend and does seem to allow me to connect Owntracks to Mosquitto. I do notice that if I route Owntracks through Orbot, it hangs for for a long time in the connecting state? Is this something anyone has experienced and, if so, is it an issue with Owntracks or Orbot?
A special thanks to the authors of the Home Assistant TOR guide.
The install went smoothly and external access to Home Assistant is now available through my Android phone.
Was thinking of the VPN route and setting up a local server but the TOR solution comfortably runs on a Raspberry Pi 3B that is already running Home Assistant.
The upshot is no extra hardware, no extra power to run another server and super security.
Thanks heaps.
RAWB
Hi! I am trying to use this configuration. I have a windows 10 machine where my HA server is, and where I installed TOR. But I am not sure how to do this change in TOR in Windows
HiddenServiceDir /var/lib/tor/homeassistant/
HiddenServicePort 80 127.0.0.1:8123
HiddenServiceAuthorizeClient stealth haremote1
I put these commands in torcc file but it gives an error and TOR does not even start.
Any ideas?
Sorry newb here
Iām following this topic with great interest. However, being new to Tor, may I know should I use it if I already have a VPN server running in my network? Both methods also need to install an app in my android. What are the advantages it have over each other?
@dbenhart Iām trying to do exaclty what you did. I have a separeate onion adress for connecting to my privat mosquitto server.
But I canāt seem to get it working.
How did you configure owntracks?
here is what I have:
- Connection: Private MQTT
- host - my mosquitto onion address
- port 1883
- no websockets
- IDENTIFICATION::authentication OFF
- SECURITY:: NO TLS
7.PARAMETERS:: clean session OFF
Any help here? how did you manage to make it work? Or maybe I should use a private HTTP? The problem is that I think it requires a CA cert then.
Unfortunately, I never got it working. Iāve checked with the Orbot crew, the HA crew, and the Owntracks people, but it still wonāt connect. Iām sure thereās a log file that I could post to show whatās going wrong, but I donāt know which one it would be.
Ok, all hope is not lost.
I got this thing to work!
- I only checked this on an android phone.
- INSTALL MOSQUITTO as a MQTT server on your machine. The hbmqtt does not work with Owntracks.
- The config from my previous post works perfectly.
So the problem here was the hbmqtt serverā¦ Aftere switching to mosquitto it works fine.
Be sure to set up the Tor hidden service properly. Meaning - right port in the torrc file.
After this make sure 3 times that you gave the addresses correctly (In the Owntracks CLIENT as well as in the ORBOT config file.
Anyone had any luck with apple phones?
I am sure I am doing something silly, but I do not understand what it is. I am trying to access my Home Assistant (0.35.3) hosted on a Pi 3b with the latest Android Orfox (downloaded 09/JAN/2017). Everything works smoothly until I try to access HA with Orfox. The following steps below is the procedure I am not 100% sure I am doing correctly. Could you please review and advise what I may be doing wrong?
1- In Orbot > Settings > Torrc Custom Config typed "HidServAuth asdfghjkl1zx2cv.onion q0wer1RTYrUI+ZXCVBnmas (THIS IS MADE UP)
2- Pressed OK
3- Pressed back button
4- Menu >Exit Orbot
5- Pressed Orbot icon and pressed START
6- Pressed BROWSE
7- Orfox opens
8- In the Orfox address bar i type āhttp://asdfghjkl1zx2cv.onionā
9- Response āThe connection has timed outā
I have also tried āasdfghjkl1zx2cv.onionā; āhttps//asdfghjkl1zx2cv.onionā; āhttp://asdfghjkl1zx2cv.onion**:8123**ā; āhttps://asdfghjkl1zx2cv.onion**:8183**ā and ""http://asdfghjkl1zx2cv.onion**:8080** without success.
Thank you in advance for your help.
The steps for accessing look allright.
What about the server side?
Can you describe how you configured the Tor on the server?
All,
Since my ISP does not let me do port forwarding I went with Tor Oninon Configuration (https://home-assistant.io/docs/ecosystem/tor/1). Since this in reality has end to end encryption do I need to a SSL Certificate in order to have this work with google home?
N8fr8,
I have installed tor but when I get to creating hostname it gives me no such directory exist, quite similar to vdarkobar.
I followed everything to see just stuck thereā¦any help would be appreciated
Iām new to a lot of this. So if I set up Tor for remote access, then this can only be access via the Tor browser, and not Chrome? Am I understanding that correctly?
Have you tried the Onion Browser 2 public beta? https://www.patreon.com/posts/quick-onion-2-0-12054247
No, you can use the Tor Onion setup without an SSL certificate just fine.
Using Tor Browser or Orfox on Android is the easiest approach, since they are setup for Tor access. That said, since your goal is access, and not anonymity, you can use Chrome, as long as it is setup to be proxied through Torās SOCKS proxy port.
Are you using a laptop or mobile to access?
You need to change the HiddenServiceDir to something that will work on windows
should be changed to something like
HiddenServiceDir c:\ha\tor
or whatever path you want on Windows
Is this on Windows? Does the folder you are specifying exist?
Iāve been using the Tor service successfully for a few weeks but I notice that the event times on the faceplates and graphs are offset incorrectly. In my case the times are shown at GMT, but iām at GMT +11hrs so the times are incorrect.
When accessed on my home network all times are correct for my local time zone.
My Home Assistant system is running on hassio on a raspberry pi3 with no unusual network connections.
Is this an issue with Tor/Orbot/Orfox not knowing my local time zone? Or is this a Home Assistant issue? Any ideas to correct this?
TiA
Mentok
At a guess itās because the tor endpoint is working on gmt, which they probably all do as part of the anonymity package.
omg of course! for some reason I thought that was a means of block commenting I was not aware ofā¦
