Hello
I hope someone could shine some light here, I’m following the guide described here: https://www.home-assistant.io/docs/ecosystem/tor (I’m running homeassistant on a debian buster based distro).
I’ve edited the torrc
file as described.
did the restart and checked the status
$: sudo systemctl restart tor
$: sudo systemctl status tor
● tor.service - Anonymizing overlay network for TCP (multi-instance-master)
Loaded: loaded (/lib/systemd/system/tor.service; enabled; vendor preset: enabled)
Active: active (exited) since Mon 2019-11-04 19:52:20 CET; 5s ago
Process: 30117 ExecStart=/bin/true (code=exited, status=0/SUCCESS)
Main PID: 30117 (code=exited, status=0/SUCCESS)
Nov 04 19:52:20 ptr-g8gd1jlrariu0qbtoee systemd[1]: Starting Anonymizing overlay network for TCP
Nov 04 19:52:20 ptr-g8gd1jlrariu0qbtoee systemd[1]: Started Anonymizing overlay network for TCP (
But the next step fails:
$ sudo more /var/lib/tor/homeassistant/hostname
more: stat of /var/lib/tor/homeassistant/hostname failed: No such file or directory
If I look in the /var/lib/tor directory, I don’t see anything homeassistant related.
:/var/lib/tor# ls -l
total 5568
-rw------- 1 debian-tor debian-tor 20442 Nov 4 19:42 cached-certs
-rw------- 1 debian-tor debian-tor 2038463 Nov 4 19:42 cached-microdesc-consensus
-rw------- 1 debian-tor debian-tor 3629219 Nov 4 19:42 cached-microdescs.new
drwx--S--- 2 debian-tor debian-tor 4096 Nov 4 19:42 keys
-rw------- 1 debian-tor debian-tor 0 Nov 4 19:42 lock
-rw------- 1 debian-tor debian-tor 3456 Nov 4 19:45 state
Any suggestion how to continue?
Thanks!
