I’ve got the following automation that works well enough:
# Security - Motion
# if motion is sensed
# when no one is home or we're in bed
- alias: motion?
platform: state
entity_id:
- binary_sensor.living_room_motion_motion
- binary_sensor.dining_room_motion_motion
- binary_sensor.upstairs_motion_sensor_motion
to: 'on'
condition:
condition: or
conditions:
- condition: template
value_template: "{{ states('group.family') != 'home' }}"
- condition: state
entity_id: input_boolean.in_bed
state: 'on'
- service: notify.mobile_app_russ_phone
message: '{{ trigger.to_state.name }} motion'
It gives a much-more-verbose-than-I’d-like message like “binarary_sensor.living_room_motion_motion motion”.
What I’d like to do is use trigger.idx to index into a less verbose list of device names, but I’m not quite sure how to set up the list so that less_verbose_list[trigger.idx] would return something like “living room”.
Any suggestions?
Your automation is using trigger.to_state.name which should be displaying the entity’s friendly_name and not its entity_id. However, if it has no friendly_name then it will display entity_id. Do the binary_sensors have friendly names?
Do you want it to display the entity’s friendly_name or something shorter?
The automation has one State Trigger so the value of trigger.idx will always be the same.
I suggest creating three separate State Triggers and give each one’s id property the desired name.
- alias: motion?
- id: 'Living Room'
platform: state
entity_id: binary_sensor.living_room_motion_motion
to: 'on'
- id: 'Dining Salon'
platform: state
entity_id: binary_sensor.dining_room_motion_motion
to: 'on'
- id: 'Sleeping Quarters'
platform: state
entity_id: binary_sensor.upstairs_motion_sensor_motion
to: 'on'
condition: "{{ states('group.family') != 'home' or is_state('input_boolean.in_bed', 'on') }}"
message: '{{ trigger.id }} motion'
If you want to only use a single State Trigger, you will need to use trigger.to_state.object_id as the key for a dictionary to find the associated short name.
Those examples are very helpful. Both are useful in their own way and I’ll probably use the second for some other things I have in mind, but the first is exactly what I want in this instance.
(I didn’t know you could do that with id:)
Thanks for this.
