Hi to all, I want write a script where tts play a random message with a given name as parameter.
This is the script:
tts_wellcome:
alias: "Wellcome"
sequence:
- service: tts.google_say
entity_id: media_player.salotto
data_template:
message: >
{{ ("Hi, {{ name }}. Wellcome back at home.",
"Wellcome back {{ name }} .",
"Happy to see you again {{ name }} !"
)|random }}
and this is the action invoking the script:
initial_state: true
- platform: state
entity_id: input_boolean.maxhome
to: 'on'
- service: script.tts_wellcome
I haven’t error in the configuration but the speaker says “name” instead of “Max”.
How can I solve this?
Sorry I have traslated the variable from italian “nome” to “name” writing the post, and i have forgot to change it, but in the code i have the right variable, “name” in this case. I have edit the post.
not sure if this is it, but try adding the entity_id to the data_template?
tts_wellcome:
alias: "Wellcome"
sequence:
data_template:
message: >
)|random }}
also, and again, probably not the cause, but there’s peculiarities with spaces in Yaml, so try:
initial_state: true
- platform: state
to: 'on'
or even leave out the dashes - if you are only listing 1 trigger or action:
initial_state: true
platform: state
to: 'on'
Unfortunatelly your suggestion doesn’t work. Dash and spaces are present because i made a copy and past of the single service, in the real I call more services
Looking deeper in the forum I have found the solution.
Thankyou anyway for your promp answer.
tts_wellcome:
alias: "Wellcome"
sequence:
data_template:
message: >
{{ ("Hi, " ~ name +". Wellcome back at home.",
"Wellcome back " ~ name +" .",
"Happy to see you again " ~ name +" !"
)|random }}
a yes, that’s because one can’t use a {{}} template in a {{}} template. You can however use a variable in a template, which is what is you are doing right now.
sorry for not picking that up.
