Using 'Ubuntu 20.04.1 LTS' as the OS is not supported
Since de 0.114 update I’ve got the “Unable to load the panel source: /api/hassio/app/entrypoint.js” error.
So, i’ve decided to restore a backup… That’s what they are for.
Now, after removing al HA related docker stuff I’ve ran in to a new issue. It won’t start due to unsupported OS?
20-08-16 14:35:05 INFO (MainThread) [supervisor.host.services] Reload local service hassio-apparmor.service,
20-08-16 14:35:05 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1,
20-08-16 14:35:05 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-dns with version 9,
20-08-16 14:35:05 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3,
20-08-16 14:35:05 INFO (MainThread) [supervisor.plugins.dns] Restart CoreDNS plugin,
20-08-16 14:35:05 INFO (SyncWorker_0) [supervisor.docker.interface] Restart homeassistant/amd64-hassio-dns,
20-08-16 14:35:10 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf,
20-08-16 14:35:10 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-audio with version 17,
20-08-16 14:35:10 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-cli with version 25,
20-08-16 14:35:10 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-multicast with version 2,
20-08-16 14:35:10 INFO (MainThread) [supervisor.plugins.multicast] Restart Multicast plugin,
20-08-16 14:35:10 INFO (SyncWorker_0) [supervisor.docker.interface] Restart homeassistant/amd64-hassio-multicast,
20-08-16 14:35:14 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json,
20-08-16 14:35:14 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/qemux86-64-homeassistant with version 0.114.0,
20-08-16 14:35:14 INFO (MainThread) [supervisor.hassos] No Home Assistant Operating System found,
20-08-16 14:35:14 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/53caca22/snapcastserver/config.json: required key not provided @ data['arch']. Got None,
20-08-16 14:35:14 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/53caca22/nextcloud/config.json: required key not provided @ data['arch']. Got None,
20-08-16 14:35:14 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/53caca22/kanboard/config.json: required key not provided @ data['arch']. Got None,
20-08-16 14:35:14 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/53caca22/mopidy_alpine/config.json: required key not provided @ data['arch']. Got None,
20-08-16 14:35:14 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/774437fd repository,
20-08-16 14:35:14 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/15ef4d2f repository,
20-08-16 14:35:14 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/243ffc37 repository,
20-08-16 14:35:14 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/53caca22 repository,
20-08-16 14:35:14 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/69bb46cb repository,
20-08-16 14:35:14 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/cebe7a76 repository,
20-08-16 14:35:14 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/7be23ff5 repository,
20-08-16 14:35:14 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository,
20-08-16 14:35:14 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/7ad98f9c repository,
20-08-16 14:35:14 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/806b11b5 repository,
20-08-16 14:35:14 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/core repository,
20-08-16 14:35:14 INFO (MainThread) [supervisor.store] Load add-ons from store: 108 all - 108 new - 0 remove,
20-08-16 14:35:14 INFO (MainThread) [supervisor.addons] Found 14 installed add-ons,
20-08-16 14:35:14 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-mariadb with version 2.2.1,
20-08-16 14:35:14 INFO (SyncWorker_4) [supervisor.docker.interface] Attach to esphome/esphome-hassio-amd64 with version 1.14.5,
20-08-16 14:35:14 INFO (SyncWorker_5) [supervisor.docker.interface] Attach to hassioaddons/nginxproxymanager-amd64 with version 0.6.0,
20-08-16 14:35:14 INFO (SyncWorker_7) [supervisor.docker.interface] Attach to sabeechen/hassio-google-drive-backup-amd64 with version 0.100.0,
20-08-16 14:35:14 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to carldebilly/zigbee2mqttassistant with version 172,
20-08-16 14:35:14 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-deconz with version 6.2.3,
20-08-16 14:35:14 INFO (SyncWorker_3) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-configurator with version 5.0.0,
20-08-16 14:35:14 INFO (SyncWorker_6) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-mosquitto with version 5.1,
20-08-16 14:35:14 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to dwelch2101/zigbee2mqtt-edge-amd64 with version test,
20-08-16 14:35:14 INFO (SyncWorker_4) [supervisor.docker.interface] Attach to dwelch2101/zigbee2mqtt-amd64 with version 1.14.3,
20-08-16 14:35:14 INFO (SyncWorker_5) [supervisor.docker.interface] Attach to poeschl/hassio-valetudo-mapper-amd64 with version 1.4.0,
20-08-16 14:35:14 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to hassioaddons/mqtt with version 1.2.0,
20-08-16 14:35:14 INFO (SyncWorker_7) [supervisor.docker.interface] Attach to hassioaddons/phpmyadmin-amd64 with version 0.1.3,
20-08-16 14:35:14 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to hassioaddons/chrony-amd64 with version 1.1.0,
20-08-16 14:35:14 INFO (MainThread) [supervisor.snapshots] Found 4 snapshot files,
20-08-16 14:35:14 INFO (MainThread) [supervisor.discovery] Load 2 messages,
20-08-16 14:35:14 INFO (MainThread) [supervisor.ingress] Load 0 ingress session,
20-08-16 14:35:14 INFO (MainThread) [supervisor.misc.secrets] Load Home Assistant secrets: 11,
20-08-16 14:35:14 ERROR (MainThread) [supervisor.core] Using 'Ubuntu 20.04.1 LTS' as the OS is not supported,
Traceback (most recent call last):,
  File "/usr/local/lib/python3.8/site-packages/docker/api/client.py", line 261, in _raise_for_status,
    response.raise_for_status(),
  File "/usr/local/lib/python3.8/site-packages/requests/models.py", line 941, in raise_for_status,
    raise HTTPError(http_error_msg, response=self),
requests.exceptions.HTTPError: 500 Server Error: Internal Server Error for url: http+docker://localhost/v1.40/images/sha256:dedee596baf898213b6c6fa3f6e85cdd241d4895929b4ee616f4fecb1b5fe32e/json,
During handling of the above exception, another exception occurred:,
  File "/usr/local/lib/python3.8/runpy.py", line 194, in _run_module_as_main,
    return _run_code(code, main_globals, None,,
  File "/usr/local/lib/python3.8/runpy.py", line 87, in _run_code,
    exec(code, run_globals),
  File "/usr/src/supervisor/supervisor/__main__.py", line 47, in <module>,
    loop.run_until_complete(coresys.core.setup()),
  File "uvloop/loop.pyx", line 1456, in uvloop.loop.Loop.run_until_complete,
  File "/usr/src/supervisor/supervisor/core.py", line 148, in setup,
    if await self.sys_run_in_executor(self.sys_docker.check_denylist_images):,
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run,
    result = self.fn(*self.args, **self.kwargs),
  File "/usr/src/supervisor/supervisor/docker/__init__.py", line 239, in check_denylist_images,
    for image in self.images.list():,
  File "/usr/local/lib/python3.8/site-packages/docker/models/images.py", line 364, in list,
    return [self.get(r["Id"]) for r in resp],
  File "/usr/local/lib/python3.8/site-packages/docker/models/images.py", line 364, in <listcomp>,
  File "/usr/local/lib/python3.8/site-packages/docker/models/images.py", line 316, in get,
    return self.prepare_model(self.client.api.inspect_image(name)),
  File "/usr/local/lib/python3.8/site-packages/docker/utils/decorators.py", line 19, in wrapped,
    return f(self, resource_id, *args, **kwargs),
  File "/usr/local/lib/python3.8/site-packages/docker/api/image.py", line 245, in inspect_image,
    return self._result(,
  File "/usr/local/lib/python3.8/site-packages/docker/api/client.py", line 267, in _result,
    self._raise_for_status(response),
  File "/usr/local/lib/python3.8/site-packages/docker/api/client.py", line 263, in _raise_for_status,
    raise create_api_error_from_http_exception(e),
  File "/usr/local/lib/python3.8/site-packages/docker/errors.py", line 31, in create_api_error_from_http_exception,
    raise cls(e, response=response, explanation=explanation),
docker.errors.APIError: 500 Server Error: Internal Server Error ("readlink /var/lib/docker/overlay2/l/4TLD5JA3UKT6LEJW4I6CQ34ANW: invalid argument"),
[cont-finish.d] executing container finish scripts...,
[cont-finish.d] done.,
[s6-finish] waiting for services.,
[s6-finish] sending all processes the TERM signal.,
[s6-finish] sending all processes the KILL signal and exiting.,
It runs’ fine on Ubuntu 20.04. I think you made a mistake somewhere in the installation, or have some corruption on your hdd.
No, I’m running 20.04.1, not 20.04. There is no corruption on my SSD. I even tried a fresh install, still te same error.
readlink errors typically indicate filesystem corruption.
Thank you for your reply.
Just checked my SSD (PCI-E). SMART tests and bad block test went fine. FSCK gave no errors.
Still same error. Checking folder “/var/lib/docker/overlay2/l/4TLD5JA3UKT6LEJW4I6CQ34ANW” on the OS gave no issues to.
Now checking with another SSD (SATA).
New SSD, same error. So no hardware related error.
Just responding to say I have the exact same error. Home assistant container doesn’t start automatically anymore. Works fine after manual start of the docker container, but can’t load supervisor panel.
Edit: after reverting to supervisor version 230, it works again. So run the following commands:
docker pull homeassistant/amd64-hassio-supervisor:202
docker tag homeassistant/amd64-hassio-supervisor:202 homeassistant/amd64-hassio-supervisor:latest
systemctl stop hassio-supervisor.service
systemctl start hassio-supervisor.service
I got it from this reply: Supervisor not starting after update to 207 · Issue #1556 · home-assistant/supervisor · GitHub
thanks, i had the same problem, supervisor updated to 234 and then went crazy.
revert back to 230 and now it’s working fine.
WTF is wrong with 234?
I wish supervisor doesn’t update automatically, i was on vacation and s**t happened :face_with_symbols_over_mouth:
I have created an issue about this, but it has already been closed, even though I’m not sure if it has really been solved:
Same thing happening with Supervisor v245
20-09-29 10:45:36 ERROR (MainThread) [supervisor.core] Detected unsupported OS: Ubuntu 20.04.1 LTS
20-09-29 10:45:37 INFO (MainThread) [__main__] Run Supervisor
20-09-29 10:45:37 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-09-29 10:45:37 CRITICAL (MainThread) [supervisor.core] System running in a unsupported environment!
This started happening after upgrading to Ubuntu 20.04.1 LTS (Docker version 19.03.13)
hi
any progress?
I run 20.04.1 on a Lenovo M93p, 8gb memory, 128gb SSD, Docker version 19.03.13 and the hassio supervised install. Been doing this for many months (previously on Raspbian for years). Apply all updates in a timely (not immediate) fashion. I have never seen any problems booting, starting, etc. Why you and not me?
running similar: 20.04 / NUC i5 16GB memory 1G HDD / Docker. No problem either… except the no support message
