I wanted to understand what happened. I moved from Ubuntu in VirtualBox on a Windows PC to a dedicated machine. Installed same version of Ubuntu, 18.04, and I copied my config folder over. I matched all the files, permissions, and users, and folders, etc…
Home Assistant fired right up, but I could not login. The salt inside the auth_provider file in .storage was different, if I copied the one from the other machine back over, it would change it again.
I used this method…
Going into the container, making a new password, updated the file, restarting,then I was working again.
Does it make the salt from something on the host? It couldn’t be in the container…
Anything else I need to look out for from moving systems?
I did scp, at first I didn’t do it as root, so it didn’t copy root owned files, but then I did sudo scp -r and then check all file counts and permissions… I had to tweak a view permissions, but I got it to match 100% with both old and new system terminals up doing comparison
Also, in the auth provider, after I ran it, HA changed the salt… So I know the issue, the salt was different, so the hash decrypted different, so my password didn’t match…
After first load I loaded auth provider on both terminals and salt on new machine was different, but it kept the user hash, or maybe it just auto generated a whole new file, not sure
If you properly copy config folder there should be no issue. Also must ensure file/folder permissions are same between systems or you may run into issues.
