Today I did buy an Unfi router setup to replace my current router.
Everything worked fine and is up and running.
Now I do like to use the unifi addon controller but I’m not able to get it running.
Installing is fine but when I open the WEBUI it gives an error that Duckdns is refusing acces.
I did use the standard configuration in the unifi addon.
ssl: false
certfile: fullchain.pem
keyfile: privkey.pem
What to do to get this addon running?
In de user manual of Frenck it says
7. Change the `Controller Hostname/IP` to match the IP or hostname of the device running Home Assistant.
8. Check the box `Override inform host with controller hostname/IP` .
9. Hit the "Apply Changes" button to activate the settings.
I can do that in my controller installed at windows, but I’m afraid that I cannot enter the controller anymore from my PC and not from HA.
I also don’t know exactly what to fill in “Controller hostname/IP”:
The ip of my RPI or the duckdns login or?
The Log looks fine?
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: UniFi Controller
Manage your UniFi network using a web browser
Add-on version: 0.14.1
There is an update available for this add-on!
Latest add-on version: null
Please consider upgrading as soon as possible.
System: HassOS 3.13 (aarch64 / raspberrypi4-64)
Home Assistant Core: 0.108.5
Home Assistant Supervisor: 217
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] unifi.sh: executing...
[cont-init.d] unifi.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[21:16:38] INFO: Starting the UniFi Controller...
Any advice please?
