Can someone tell me if this is valid way to use the useId as it’s not working. I’m using this parameter in a condition in another automation and it works fine.
You changed a couple things at once it looks like. Did it not work because of the shape of parameters, or because it was the wrong node ID or wrong user ID?
My apologies. You are correct. I use the code detection to turn a scene for Guest Mode on. When I initially tried your code, Guest mode would activate then go off seconds later when the lock closed so I added the event_label without then trying your code again. The Guest Mode should only go off when one of the house owners unlocks the door and this appears to be working flawlessly now. Really appreciate your quick response and advice.
No worries, was just curious as to whether that format worked or not. In YAML, the two are equivalent, so I was expecting the trigger to work the same. Thanks for confirming.
