deltabert
(Bert)
September 26, 2022, 6:55am
1
Hi all,
I have an automation, where I use two different times and a template where these times are being used.
alias: 40 - Test switch On Off at preset times
- platform: time
at:
- "20:10:00"
- "20:40:00"
- platform: homeassistant
event: start
- service: >-
switch.turn_{{ iif( (20,10) <= (now().hour, now().minute) < (20,40), 'on'
, 'off') }}
entity_id: switch.wcd_lidl_3
How can I use variables for both time values, so when i change the time at trigger: it also changes the times in the Template
tom_l
September 26, 2022, 7:29am
2
If you want to change them from the frontend create and use two input datetime helpers with time only.
- platform: time
at:
- input_datetime.one
- input_datetime.two
event: start
- service: >-
switch.turn_{{ iif( today_at(states('input_datetime.one')) <= now() < today_at(states('input_datetime.two')), 'on'
, 'off') }}
deltabert
(Bert)
September 26, 2022, 7:40am
3
Thank you @tom_l . Ok, that looks not to hard to do.
But what if I do not want to use the frontend, but want to set the times in the automation itself, to put the time value in the helper? Is there a way to do that?
tom_l
September 26, 2022, 7:46am
4
Sure. You have to reload automations every time you change the times though:
variables:
time_1: "20:10:00"
time_2: "20:40:00"
- platform: time
at:
- time_1
- time_2
event: start
- service: >
switch.turn_{{ iif( today_at(time_1) <= now() < today_at(time_2), 'on'
, 'off') }}
deltabert
(Bert)
September 26, 2022, 7:50am
5
Ah, great, did not know the use of variables within the automation… Have to learn a lot. I will try both options. And yes, perhaps the frontend version is a better choice.
Found a tutorial about the use of frontend with helpers:
How To Use HELPERS In Home Assistant - TUTORIAL
Thank you!
tom_l
6
Sorry I misread your post. The variables are local to that automation only.
You can use the input_datetime.set_datetime service to set the times in another automation if using my first example.
https://www.home-assistant.io/integrations/input_datetime/#input_datetimeset_datetime
deltabert
(Bert)
September 27, 2022, 10:42am
7
Hi @tom_l I am sorry, i deleted my entry because i want to test something else fist…
