Using variables in condition template automation
Hello i’m trying to use variables inside automation without success.
what’s wrong?
alias: Gestione Temperatura e Umidità Camera Grande con variabili
description: ""
  - platform: state
    entity_id:
      - sensor.clima_big_inside_temperature
      - sensor.clima_big_humidity
      - sensor.monit_casa_e_fotovoltaico_channel_1_power
  - variables:
      temperature_target: "{{ state_attr('climate.clima_big', 'temperature') }}"
      humidity_target: "{{ states('sensor.clima_big_target_humidity') | float }}"
      temp: "{{ states('sensor.clima_big_inside_temperature') | float }}"
      humidity: "{{ states('sensor.clima_big_humidity') | float }}"
  - choose:
      - conditions:
          - condition: template
            value_template: >-
              {{ states('sensor.monit_casa_e_fotovoltaico_channel_1_power') |
              float > 100 }}
        sequence:
          - service: climate.turn_off
              entity_id: climate.clima_big
            data: {}
      - conditions:
            value_template: >-
              float <= 100 }}
            value_template: >
              {{ temp > temperature_target or (humidity not in ['unknown',
              'unavailable', 'None'] and humidity | float > humidity_target) }}
        sequence:
          - service: climate.turn_on
            data: {}
      - conditions:
            value_template: >-
              float <= 100 }}
            value_template: >
              {{ temp <= temperature_target and (humidity in ['unknown',
              'unavailable', 'None'] or humidity | float <= humidity_target) }}
        sequence:
            data: {}
  - service: homeassistant.update_entity
      entity_id:
    data: {}
You supply float with a default value.
  1. If float cannot convert the supplied value to a number, it will report the default value.
  2. If no default value is provided and it cannot convert the value, the template fails with an error.
In the following example, if float cannot convert the sensor’s value to a number, it will report 0 so the test becomes 0 > 100. Without a default value, the template would simply fail.
            value_template: >-
              float(0) > 100 }}
In the following example, if float can’t convert the sensor’s value (because it’s unavailable or unknown) it will report 20. You can set the default value to be whatever number is the best choice for your application.
temp: "{{ states('sensor.clima_big_inside_temperature') | float(20) }}"
thanks to fix my code however that part is working… what donesn’t work is the part related the variables which always said “not passed” but with gray color… nor organge as usually… so i guess something doesn’t work here or something related the variable setup.
            value_template: >
Where are you seeing these colors and “not passed” message? In the Automation Editor? Don’t use that for testing Template Conditions, especially when they contain variables defined outside of the actual template.
but the result should be pass looking the values.
No, because it only evaluates the template, not any other part of your automation, like the variables section. So it doesn’t know what temp or temperature_target or humidity are because they are defined outside of the template.
Here’s a simple example:
alias: example 123456
  - platform: state
    entity_id: sensor.foo
  - variables:
      x: 1
      y: 2
  - choose:
      - conditions:
            value_template: "{{ x + y == 3 }}"
        sequence:
          - service: notify.persistent_notification
              title: Test
              message: "{{ x }}, {{ y }}"
    default: []
The Template Condition “Did Not Pass” because the variables x and y are defined outside of the template and the Automation Editor only evaluates what is known in the template.
You can’t test Template Conditions in the Automation Editor if the template references variables defined outside of the template.
you are totally right. it was unknown from my side. thanks for explanation
You’re welcome!
You’re not the only person who has been misled by the way the Automation Editor tests Template Conditions. Ideally it should process the variables section but it doesn’t. It limits its processing to Jinja2 code in the template and excludes processing any YAML (like what is defined in the variables section).
I suppose what would be a little bit better is if it posted an error message when it encounters a problem with the template (such as "found undefined variables: temp, humidity, …) like what is shown in the Template Editor.
