I downloaded the customization for input variables, but I have my formatting incorrect for storing a sensor value within that variable. I could probably steal a yaml example, but for now id like to stick to the GUI until I am more comfortable
What is the correct formatting in this situation? I have tried several
Do you mean you have installed a custom integration? Which oneā¦? There are several related to āvariablesā, each with itās own particular configuration specifications.
I guess I forgot to attach the screenshot, sorry. I have updated the original post
The integration I have installed is here.
The attached picture should give you an idea of what I am trying to do.
Use Case:
I have created a virtual thermostat from a basic temp sensor. Between Sunset and Sunrise (sleep time) I want the bedroom virtual thermostat to control the house so that my bedroom stays the temp that I expect.
I plan to do this by setting the living room (main) thermostat to a low temp like 65 and then using the virtual thermostat to toggle the mode on and off as needed. After sunrise, I will return the mode and temp to their previous settings (captured at the beginning of the automation)
Bumping this thread because I have a very similar use case. Iām getting my head round YAML but I like to keep automations visible in the GUI unless absolutely unavoidable.
I have an automation called ābathroom boostā which when pressing the button, will crank up the underfloor heating and towel rail temperature and start a timer counting down. There is then another trigger to detect when the timer expires, to turn everything back down again.
BUT rather than just turning off the thermostats completely or setting to some default value, Iād like to return them to their previous value.
So to my mind, that requires setting a āhelperā attribute to store the current thermostat temp when invoking the boost, then to set it back to that value when the boost expires.
Is this possible via the front end, by entering a template value instead of an absolute value in centigrade, when calling the set thermostat service?
I have the same with a Nest Thermostat.
Since some time, i cannot retrieve the current temperature value set on the device and save it to a variable. Keeps unknown.
