Using VSC on Multiple HA Instances ? Any Tips?
I know this isn’t ‘strickly’ a configuration issue … but where to put ‘some things’ is hard …
Okay I have VSC running on a windows PC and I have two HA instances.
How do you connect to both instances ?
Next Issue : I’m going to swap to an Ubuntu Workstation, How can you connect VSC to two instances from that ?
I apologise in advance as this may be considered two questions under one post AND may require input from both the windows and linux camps :crazy_face:
Thanks In Advance for any advice offered
