Using your Spotify account in a HA dashboard to select speakers and broadcast anything in your Spotify account devices {and Alexa if you linked your Spotify Account in your Alexa app} in Home assistant. This works best with a paid Spotify account but I think works a free account.
Spotify dashboard
First you need Spotify integration set up in HA and Spot cast from HACS and optional spotify card.
Spotify Spotify - Home Assistant
Spotify-card GitHub - custom-cards/spotify-card: Spotify playlist card for Home Assistant card
There are many ways of doing this by getting the URL of the playlist or songs in your Spotify account and doing a bunch of fumbling around. But I found this is a much more simple way by using the HA guys awesome media-browser dashboard that you can choose from Spotify then anything you want like songs, categories or playlist from your Spotify account linked to HA.
Create a speaker Drop down list {Speakers}
Make a drop down list to be used in Device selected automation.
with Helpers or a input select by hand In your input select: configuration.yaml section or file.
Drop down list using Helpers.
speakers HELPER screenshot
Input select yaml by hand.
input_select:
speakers:
options:
- "Family room"
- "Living Room speaker"
- "Living Room TV"
- "Kitchen display"
- "Bedroom speaker"
icon: mdi:cast-audio
Make sure you use the names exactly {case sensitive} of Chromecast, Alexa or other devices or speaker groups in your SPOTIFY Account or Google home account not the name you gave in HA.
You can get this list in your Spotify device list.
Or looking at custom:spotify-card speaker list spot cast HACS add on.
spotify device list screen shot
spotcast card
Create a media selection (music playlist) List drop down {Music Playlist }
Make a drop down list to be used in Music Playlist automation.
with Helpers or a input select by hand In yaml.
Use any name you would like for each Media selection for it will be used in the automation to select Media from Spotify in the automation.
My media selection Drop down list using Helpers
music playlist screen shot
Create a script to activate spot cast when speakers are selected using YAML or HA UI in automations & Scenes tab.
This script has my options of setting volume to 30 and shuffle you can change or remove.
start spotcast script screenshot
service: spotcast.start
device_name: "{{ states('input_select.speakers') }}"
force_playback: true
start_volume: 30
shuffle: true
Device Selected automation…
alias: "Spotify: Device Selected2"
description: Starts music playing on the selected Chromecast Audio device
- platform: state
entity_id: input_select.speakers
condition: []
- service: script.turn_on
data: {}
entity_id:
- script.spotify_start_playback
mode: single
device selected automation screenshot
Play list automation
Linking your Music Playlist Drop down list to your Spotify Media selection.
The target action media player is your Spotify HA account media player. Using the media-browser the HA staff created.
( entity_id: media_player.spotify_smarthome1)
spotify intergration SCREEN SHOT.
media browser screenshot
Music playlist Automation
The first automation below works great. But if Spotify is not already started or active on a device and you select music playlist you need to click the RUN next to Spotify:Start playback after selecting.
start spotify screenshot
Place this code in a UI editor automation editor
Or in your own automation.yaml.
UI playlist automation screenshot
yaml
alias: "Music Playlist "
description: ""
- platform: state
entity_id:
- input_select.playlist
to: "Rock out "
- platform: state
entity_id:
to: "Cleaning "
- platform: state
entity_id:
to: Relax
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- service: media_player.play_media
media_content_id: spotify:playlist:2gvmi685aThtmb1cirWNRS
media_content_type: spotify://playlist
metadata:
title: "rods playlist "
thumbnail: https://i.scdn.co/image/ab67616d0000b27343de9079ae02773c1fae9a26
media_class: playlist
children_media_class: track
navigateIds:
- media_content_type: spotify://current_user_playlists
media_content_id: current_user_playlists
- media_content_type: spotify://playlist
- conditions:
sequence:
media_content_id: spotify:playlist:286CJ3BIOOiiXBWcXdK7gI
metadata:
title: "our playlist "
thumbnail: >-
https://mosaic.scdn.co/640/ab67616d0000b2731336b31b6a1799f0de5807acab67616d0000b27334559f859e2522719de48ff3ab67616d0000b2734408c01a8909ee878c2a42f2ab67616d0000b273b98aacb957a40d613445f92f
navigateIds:
- conditions:
sequence:
media_content_id: spotify:playlist:6KrFnLwZfBHeJc8FAAUFji
metadata:
title: 70's Soft Rock Essentials
thumbnail: https://i.scdn.co/image/ab67616d0000b273ac2fd4d587d556ae41bd64d7
navigateIds:
enabled: true
mode: single
Optional code for above automation add start spot cast script to have spot cast start when selecting playlist if spotify is not active. Works but a little slower and changes volume each time you change playlist if you set volume level in script.
description: ""
- platform: state
entity_id:
to: "Rock out "
- platform: state
entity_id:
to: "Cleaning "
- platform: state
entity_id:
to: Relax
condition: []
- choose:
- conditions:
sequence:
metadata:
navigateIds:
data: {}
entity_id:
- conditions:
sequence:
metadata:
thumbnail: >-
navigateIds:
data: {}
entity_id: script.spotify_start_playback
- conditions:
sequence:
metadata:
navigateIds:
data: {}
enabled: true
mode: restart
Dashbord
I have this in a separate dash board called tablet in a one card Panel view but you can add in anywhere.
card1 screenshot
card2 screenshot
type: horizontal-stack
cards:
- type: vertical-stack
cards:
- square: false
columns: 1
type: grid
cards:
- type: custom:mini-media-player
entity: media_player.spotify_smarthome1
artwork: full-cover
info: scroll
source: full
sound_mode: icon
replace_mute: stop
volume_stateless: false
toggle_power: true
group: true
cards:
- type: entities
entities:
- entity: input_select.speakers
- entity: script.spotify_start_playback
- entity: input_select.playlist
title: 'pick media '
state_color: false
- type: entity-filter
entities:
- entity: media_player.nestmini5944
- entity: media_player.kitchen_nest
- entity: media_player.nestmini7847
- entity: media_player.bedroom_tv
- entity: media_player.livingroomtv
state_filter:
- playing
card:
type: entities
view_layout:
position: main
This is the entities filter that only shows active players on the card.
Make sure you add all your Home assistant players used in the Drop down list in the list or they will not show up when active.
strong text
Dont forget to reload scrips in Developer tools before you try this out.
Bonus automation using just Spot cast in HA UI automation.
I wanted to play a joke on Barbara so I did this little automation when she used the bathroom and the lamp triggered it played a random potty time song from Spotify.
description: ""
- platform: state
entity_id:
- light.bathroom_lamp
to: "on"
condition:
- condition: state
entity_id: binary_sensor.work_time_time_block
state: "on"
enabled: true
- service: spotcast.start
device_name: Bedroom speaker
start_volume: 58
uri: spotify:playlist:56ZJEeDFOZvQ4CABazkAVG?
random_song: true
mode: single
My background. I am NO coder or expert. I write thies long drawn out explanations on how to do things in HA because it take me forever to figure out the GEEK language in most help files.
I have been using sonoff devices and ewelink with IFTTT for about 3 years to automate my home and heating and evaporative cooler. I made the jump to HA and I have been playing with Home assistant since 2018. I’m enjoying playing with WLED
I made a automatic fish feeder, a LED clock and a lamp with ESPHOME also.
Over 30 years I have been installing and servicing Hearth products specializing in Gas and wood pellet burning stoves.
Home automation is a hobby I needed.
my Facebook page diyredneck.thestovedoc.com
