There’s no such thing as a dead battery node. The driver cannot tell whether a battery device is simply sleeping, or completely offline, so it will never mark them as dead. It has no heuristic to consider whether a battery device might be offline based on any kind of last communication time. I don’t think the driver maintains a “last active” node property itself (or at least it doesn’t expose one), so the applications need to do it.
Some options, maybe others can suggest something else I’ve missed:
There’s a disabled-by-default “node status” sensor who’s state is alive / sleeping / awake / dead, etc. If the node is waking up regularly, configured via the wake up interval, that sensor should toggle between alive and sleeping during the wakeup time. You could detect this state change.
If there are some sensors or notifications that change within an expected time interval, so you could detect these state changes or events. For example, my smoke alarms send a heartbeat message every 70 minutes.
You could refresh some entity, like the battery level sensor, and verify that the entity was updated within the device’s wake-up interval. The driver will queue up the Get and send it when the device wakes up, and that should trigger an update on the sensor, I believe even if the state does not change.
I think all of these HA examples would require HA to be active when the device communicates, so there’s always a possibility an event is missed if HA is offline during the wake up time. That could be handled by accepting one or more missed updates, up to a desired threshold.
zwavejs2mqtt has a "lastActive" field in the MQTT node info. This should be updated from any communication coming from the device. Create a template sensor based on the node info MQTT topic and JSON field and you can monitor the last time it communicated. Add a ping every so often to make sure there is some communication for quiet devices. Since zwavejs2mqtt is always online when the driver is up, it will never miss an update from the device. Of course, the MQTT broker will need to be online for HA to see any updates, but at least it can update from historical values.
