I can successfully pair the remote, but I’m supposed to see the actions of each button press when using zha_event, but I can’t see anything. But I do get some other things in my log-file, for each button press, but it is not a zha_event type.
When receiving the frame it says its from an unkown device
“Received frame from unknown device: 0xab36”
Below are the logs from every button. What can I do with this kind of information?
left arrow
2020-12-30 00:54:50 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|2: 170>, 32]
2020-12-30 00:54:50 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_indication (1, 1)
2020-12-30 00:54:50 DEBUG (MainThread) [zigpy_deconz.api] APS data indication response: [32, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, , 157, , 1, 260, 5, b’\x05|\x11g\x07\x00\x01\r\x00’, 0, 175, 167, 164, 0, 1, 4, -70]
2020-12-30 00:54:50 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Received frame from unknown device: 0xab36
2020-12-30 00:54:50 DEBUG (MainThread) [zigpy_deconz.api] ‘aps_data_indication’ response from , ep: 1, profile: 0x0104, cluster_id: 0x0005, data: b’057c11670700010d00’
right arrow
2020-12-30 00:54:51 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|2: 170>, 32]
2020-12-30 00:54:51 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_indication (1, 1)
2020-12-30 00:54:51 DEBUG (MainThread) [zigpy_deconz.api] APS data indication response: [30, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, , 1, , 11, 260, 0, b’\x18<\n\x01\x00 B’, 0, 175, 215, 164, 0, 1, 4, -64]
2020-12-30 00:54:51 DEBUG (MainThread) [zigpy.zcl] [0xcecf:11:0x0000] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=60 command_id=Command.Report_Attributes>
2020-12-30 00:54:51 DEBUG (MainThread) [zigpy.zcl] [0xcecf:11:0x0000] ZCL request 0x000a: [[Attribute(attrid=1, value=)]]
2020-12-30 00:54:51 DEBUG (MainThread) [zigpy.zcl] [0xcecf:11:0x0000] Attribute report received: app_version=66
2020-12-30 00:54:51 DEBUG (MainThread) [zigpy_deconz.api] ‘aps_data_indication’ response from , ep: 11, profile: 0x0104, cluster_id: 0x0000, data: b’183c0a01002042’
dim up
2020-12-30 00:56:07 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|2: 170>, 32]
2020-12-30 00:56:07 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_indication (1, 1)
2020-12-30 00:56:07 DEBUG (MainThread) [zigpy_deconz.api] APS data indication response: [30, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, , 157, , 1, 260, 8, b’\x01h\x06\x00+\x05\x00’, 0, 175, 143, 164, 0, 1, 2, -73]
2020-12-30 00:56:07 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Received frame from unknown device: 0xab36
2020-12-30 00:56:07 DEBUG (MainThread) [zigpy_deconz.api] ‘aps_data_indication’ response from , ep: 1, profile: 0x0104, cluster_id: 0x0008, data: b’016806002b0500’
dim down
2020-12-30 00:56:12 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|2: 170>, 32]
2020-12-30 00:56:12 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_indication (1, 1)
2020-12-30 00:56:12 DEBUG (MainThread) [zigpy_deconz.api] APS data indication response: [32, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, , 157, , 1, 260, 8, b’\x01i\x02\x01+\x05\x00\x00\x00’, 0, 175, 95, 164, 0, 1, 4, -79]
2020-12-30 00:56:12 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Received frame from unknown device: 0xab36
2020-12-30 00:56:12 DEBUG (MainThread) [zigpy_deconz.api] ‘aps_data_indication’ response from , ep: 1, profile: 0x0104, cluster_id: 0x0008, data: b’016902012b05000000’
on/off center button
2020-12-30 00:57:06 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|2: 170>, 32]
2020-12-30 00:57:06 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_indication (1, 1)
2020-12-30 00:57:06 DEBUG (MainThread) [zigpy_deconz.api] APS data indication response: [26, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, , 157, , 1, 260, 6, b’\x01j\x02’, 0, 175, 143, 164, 0, 1, 2, -73]
2020-12-30 00:57:06 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Received frame from unknown device: 0xab36
2020-12-30 00:57:06 DEBUG (MainThread) [zigpy_deconz.api] ‘aps_data_indication’ response from , ep: 1, profile: 0x0104, cluster_id: 0x0006, data: b’016a02’
2020-12-30 00:57:06 DEBUG (MainThread) [zigpy_deconz.api] APS data indication response: [30, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, , 1, , 11, 260, 6, b’\x18=\n\x00\x00\x10\x01’, 0, 175, 215, 164, 0, 1, 4, -64]
2020-12-30 00:57:06 DEBUG (MainThread) [zigpy.zcl] [0xcecf:11:0x0006] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=61 command_id=Command.Report_Attributes>
2020-12-30 00:57:06 DEBUG (MainThread) [zigpy.zcl] [0xcecf:11:0x0006] ZCL request 0x000a: [[Attribute(attrid=0, value=)]]
2020-12-30 00:57:06 DEBUG (MainThread) [zigpy.zcl] [0xcecf:11:0x0006] Attribute report received: on_off=1
2020-12-30 00:57:06 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.tz3000_kdi2o9m6_ts011f_870acdfe_on_off, old_state=<state switch.tz3000_kdi2o9m6_ts011f_870acdfe_on_off=off; friendly_name=_TZ3000_kdi2o9m6 TS011F 870acdfe on_off @ 2020-12-30T00:54:39.432369+01:00>, new_state=<state switch.tz3000_kdi2o9m6_ts011f_870acdfe_on_off=on; friendly_name=_TZ3000_kdi2o9m6 TS011F 870acdfe on_off @ 2020-12-30T00:57:06.450132+01:00>>
2020-12-30 00:57:06 DEBUG (MainThread) [zigpy_deconz.api] ‘aps_data_indication’ response from , ep: 11, profile: 0x0104, cluster_id: 0x0006, data: b’183d0a00001001’
Which firmware are you using for Conbee? I’m on and older version as I’m having huge problems updating the firmware for it.
