I am trying to configure USPS connector. This is the entry in configuration.yaml:
- platform: usps
username: !secret usps_username
password: !secret usps_password
When I restart my HA, I receive the following:
About
Home Assistant
0.49.1
Path to configuration.yaml: /home/homeassistant/.homeassistant
Developed by a bunch of awesome people.
Published under the Apache 2.0 license
Source: server — frontend-ui
Built using Python 3, Polymer 1.9.2, Icons by Google and MaterialDesignIcons.com.
The following errors have been logged this session:
2017-07-29 14:51:02 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 381, in async_process_entity
new_entity, self, update_before_add=update_before_add
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 212, in async_add_entity
yield from self.hass.async_add_job(entity.update)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/sensor/usps.py", line 124, in update
self._state = len(myusps.get_mail(self._session))
File "/home/homeassistant/.homeassistant/deps/myusps/__init__.py", line 176, in wrapped
return function(*args)
File "/home/homeassistant/.homeassistant/deps/myusps/__init__.py", line 229, in get_mail
container = _require_elem(response, INFORMED_DELIVERY_TAG, INFORMED_DELIVERY_ATTRS)
File "/home/homeassistant/.homeassistant/deps/myusps/__init__.py", line 89, in _require_elem
raise ValueError('No element found')
ValueError: No element found
Can someone help with this?
If I remove USPS from configuration, I do not have any errors at all.
