Hi all,
Ive set up Utility Meter last week with day,week & monthly options all with peak and offpeak tarifs.
All the sensors have created fine and the automation i set up is changing them at the correct times,
they seem to be showing the correct values and reset themselves etc.
However the Monthly Peak sensor is nowhere near accurate as you can see in the picture for some reason its in the hundreds of thousands which is messing up my other linked sensors.
I’ve doubled checked everything and can’t work out why, i know it says they won’t be accurate until the first of the month but the offpeak monthly sensor seems to be ok.
Anyone any ideas?
