I am wondering if anyone can help. I have an IotaWatt that is working well and is integrated to HA. It provides me with a sensor called sensor.mainsexport_wh that shows how much I export to the grid (from solar production). I previously was able to select this sensor and add it to the “return to grid” section in the energy dashboard. I recently added a utility meter to break down the rates I get for solar return (I get certain rate for the first 10kWh a day and other rate above it so I defined two tariffs - high and low). However, after adding the utility meter, the original sensor stopped showing as an option in the dashboard and the utility meter sensors are not showing either. I have other sensors from the IotaWatt that work fine, including my grid import sensor which is also defined through a utility meter and works fine. I tried removing the utility meter but to see if the original sensor will come back but it hasn’t. What can be the problem?
The sensors are:
The utility meter configuration:
utility_meter:
daily_solar_export:
source: sensor.mainsexport_wh
cycle: daily
name: Daily solar export
unique_id: utility_meter_daily_solar_export
tariffs:
- high
- low
Update:
I removed and reinstalled the IotaWatt integration and now I can select sensor.mainsexport_wh in energy dashboard but the utility meter sensors (sensor.daily_solar_export_high and sensor.daily_solar_export_low) are still not showing up as options. I have no problem using other utility meter sensors (which are also based on a IotaWatt sensor) in the energy dashboard. Other than different names the two utility meters are the same.
