Utility Meter and records created in table state_attributes
I was analyzing the size of my Sqlite database, and trying to figure out what was the main consumer of space.
SELECT sum(pgsize - unused) / 1024 / 1024 MB_USED,
       sum(pgsize) / 1024 / 1024 MB_ALLOC,
       name
  FROM dbstat
 GROUP BY name
 ORDER BY 1 DESC;
MB_USED	    MB_ALLOC	name
419	        447	        state_attributes
273	        275	        states
105	        105	        ix_states_context_id_bin
82	        82	        ix_states_metadata_id_last_updated_ts
72	        73	        ix_states_last_updated_ts
56	        56	        ix_states_old_state_id
53	        53	        ix_states_attributes_id
49	        49	        statistics
40	        40	        ix_states_event_id
29	        29	        statistics_short_term
16	        16	        ix_statistics_statistic_id_start_ts
16	        16	        ix_state_attributes_hash
13	        13	        ix_statistics_start_ts
10	        10	        ix_statistics_short_term_statistic_id_start_ts
8	        8	        ix_statistics_short_term_start_ts
0	        0	        statistics_runs
In my case I have a bunch of sensors that update very frequent, so the size of states is normal.
But the size of state_attributes is not.
I drilled down, and found that the culprit was all my utility meter sensors:
SELECT count( * ),
       'COLLECTING_ENERGY' type
  FROM state_attributes
 WHERE shared_attrs LIKE '%"status":"collecting"%"device_class":"energy"%'
UNION ALL
SELECT count( * ),
       'OTHER' type
 WHERE shared_attrs NOT LIKE '%"status":"collecting"%"device_class":"energy"%';
count(*) type
1112722 COLLECTING_ENERGY
21486 OTHER
SELECT entity_id
  FROM states_meta
 WHERE metadata_id IN (
           SELECT DISTINCT metadata_id
             FROM states
            WHERE attributes_id IN (
                      SELECT DISTINCT attributes_id
select * from state_attributes where shared_attrs like '%"status":"collecting"%"device_class":"energy"%';
For example, a utility meter of my hot water boiler, I have 3 for this appliance (day, month, forever), is generating a lot of records, 20k records in the period of 7 days (I have purge_keep_days: 7 in recorder configuration)
select * from state_attributes where shared_attrs like '%"friendly_name":"Cilindro diário"}%'
{"state_class":"total_increasing","source":"sensor.cilindro_switch_0_energy","status":"collecting","last_period":"8.015380","last_valid_state":"0.005664","meter_period":"daily","cron pattern":"0 0 * * *","last_reset":"2023-05-18T23:00:00.006326+00:00","unit_of_measurement":"kWh","device_class":"energy","icon":"mdi:counter","friendly_name":"Cilindro diário"}
{"state_class":"total_increasing","source":"sensor.cilindro_switch_0_energy","status":"collecting","last_period":"6.785448","last_valid_state":"0.024666","meter_period":"daily","cron pattern":"0 0 * * *","last_reset":"2023-05-24T23:00:00.019142+00:00","unit_of_measurement":"kWh","device_class":"energy","icon":"mdi:counter","friendly_name":"Cilindro diário"}
{"state_class":"total_increasing","source":"sensor.cilindro_switch_0_energy","status":"collecting","last_period":"9.267504","last_valid_state":"9.235814","meter_period":"daily","cron pattern":"0 0 * * *","last_reset":"2023-05-23T23:00:00.014354+00:00","unit_of_measurement":"kWh","device_class":"energy","icon":"mdi:counter","friendly_name":"Cilindro diário"}
{"state_class":"total_increasing","source":"sensor.cilindro_switch_0_energy","status":"collecting","last_period":"8.401274","last_valid_state":"0.009313","meter_period":"daily","cron pattern":"0 0 * * *","last_reset":"2023-05-21T23:00:00.018660+00:00","unit_of_measurement":"kWh","device_class":"energy","icon":"mdi:counter","friendly_name":"Cilindro diário"}
{"state_class":"total_increasing","source":"sensor.cilindro_switch_0_energy","status":"collecting","last_period":"6.573446","last_valid_state":"6.517286","meter_period":"daily","cron pattern":"0 0 * * *","last_reset":"2023-05-22T23:00:00.087744+00:00","unit_of_measurement":"kWh","device_class":"energy","icon":"mdi:counter","friendly_name":"Cilindro diário"}
{"state_class":"total_increasing","source":"sensor.cilindro_switch_0_energy","status":"collecting","last_period":"9.267504","last_valid_state":"0.014591","meter_period":"daily","cron pattern":"0 0 * * *","last_reset":"2023-05-23T23:00:00.014354+00:00","unit_of_measurement":"kWh","device_class":"energy","icon":"mdi:counter","friendly_name":"Cilindro diário"}
{"state_class":"total_increasing","source":"sensor.cilindro_switch_0_energy","status":"collecting","last_period":"9.267504","last_valid_state":"9.237438","meter_period":"daily","cron pattern":"0 0 * * *","last_reset":"2023-05-23T23:00:00.014354+00:00","unit_of_measurement":"kWh","device_class":"energy","icon":"mdi:counter","friendly_name":"Cilindro diário"}
{"state_class":"total_increasing","source":"sensor.cilindro_switch_0_energy","status":"collecting","last_period":"6.785448","last_valid_state":"0.02052","meter_period":"daily","cron pattern":"0 0 * * *","last_reset":"2023-05-24T23:00:00.019142+00:00","unit_of_measurement":"kWh","device_class":"energy","icon":"mdi:counter","friendly_name":"Cilindro diário"}
{"state_class":"total_increasing","source":"sensor.cilindro_switch_0_energy","status":"collecting","last_period":"6.573446","last_valid_state":"6.518963","meter_period":"daily","cron pattern":"0 0 * * *","last_reset":"2023-05-22T23:00:00.087744+00:00","unit_of_measurement":"kWh","device_class":"energy","icon":"mdi:counter","friendly_name":"Cilindro diário"}
{"state_class":"total_increasing","source":"sensor.cilindro_switch_0_energy","status":"collecting","last_period":"8.401274","last_valid_state":"2.720321","meter_period":"daily","cron pattern":"0 0 * * *","last_reset":"2023-05-21T23:00:00.018660+00:00","unit_of_measurement":"kWh","device_class":"energy","icon":"mdi:counter","friendly_name":"Cilindro diário"}
{"state_class":"total_increasing","source":"sensor.cilindro_switch_0_energy","status":"collecting","last_period":"8.748101","last_valid_state":"10.211658","meter_period":"daily","cron pattern":"0 0 * * *","last_reset":"2023-05-19T23:00:00.043037+00:00","unit_of_measurement":"kWh","device_class":"energy","icon":"mdi:counter","friendly_name":"Cilindro diário"}
Is it really necessary to save all this redundant information, I think, we only need the most recent value in this table, since the value itself is in the STATES table.
Instead of an insert maybe an update, if not for every type, at least for utility meters? Or am I missing something from workflow / architecture of Home Assistant.
DANGER
Entities that generate a significant amount of state changes can quickly increase the size of the database when the extra_state_attributes also change frequently. Minimize the number of extra_state_attributes for these entities by removing non-critical attributes or creating additional sensor entities.
https://developers.home-assistant.io/docs/core/entity#generic-properties
