Utility Meter- confirmation of setup
Hello everybody,
can you tell me if the configuration fits?
I thank you.
configuration.yaml
utility_meter:
  daily_energy:
    source: sensor.energie_verbrauch_kwh
    cycle: daily
    tariffs:
      - peak
      - offpeak
  weekly_energy:
    cycle: weekly
    tariffs:
      - peak
      - offpeak
  monthly_energy:
    cycle: monthly
    tariffs:
      - peak
      - offpeak
  yearly_energy:
    cycle: yearly
    tariffs:
      - peak
      - offpeak
  sensors:
    energie_verbrauch_kwh:
      value_template: "{{ states('sensor.energieverbrauch') | int /1000 }}"
esphome configuration
  - platform: pulse_counter
    pin: D4
    unit_of_measurement: 'W'
    update_interval: 60s
    filters:
    #  - multiply: 0.06 # in kW
      - multiply: 6 # in W
    accuracy_decimals: 0
    icon: 'mdi:flash'
home assistant automation
alias: Peak / offPeak Werktage
description: HT Werktage 06-22
  - platform: time
    at: '06:00:00'
  - platform: time
    at: '22:00:00'
condition:
  - condition: time
    weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
  - service: utility_meter.next_tariff
    data: {}
    entity_id: utility_meter.daily_energy
    data: {}
    entity_id: utility_meter.weekly_energy
    data: {}
    entity_id: utility_meter.monthly_energy
    data: {}
    entity_id: utility_meter.yearly_energy
mode: single
alias: Peak / offPeak Samstag
description: HT Samstag 00-13
  - platform: time
    at: '00:00:00'
  - platform: time
    at: '13:00:00'
condition:
  - condition: time
    weekday:
      - sat
    data: {}
    data: {}
    data: {}
    data: {}
mode: single
alias: Peak / offPeak Sonntag
description: HT Samstag 06-00
  - platform: time
    at: '06:00:00'
  - platform: time
    at: '00:00:00'
condition:
  - condition: time
    weekday:
      - sun
    data: {}
    data: {}
    data: {}
    data: {}
mode: single
No. This is not valid. You are using a power sensor to feed thee utility meter. It requires an energy sensor.
Dividing your power by 1000 gives kW, (still power) not kWh (energy).
To convert your power sensor into an energy sensor (if one is not available from the device) you need to use the integral sensor instead of the template sensor:
Is that right?`
- platform: integration
  source: sensor.energieverbrauch
  name: aktueller Verbrauch
  unit_prefix: k
  round: 2
It has the right unit for energy, but that is all I can say from your screen shot.
Does the value always increase and never decrease?
If so, then yes that is what you should feed to the utility meter.
I think the value increases, the way it looks.
thank you again
