@gieljnssns First of all, thank you for sharing you configuration. I’m studying it while trying to create a meter for the capaciteitstarief of the current month and of the current quarter.
I do not fully understand however why you already decide on the max value of the sensor.quarter_hourly_grid_consumption * 4
vs input_number.max_peak_2
rather than just return sensor.quarter_hourly_grid_consumption * 4
(see My-Hassio-config/energy.yaml at 56b473f09d59977c6f43c423e552cf6195614ef4 · gieljnssns/My-Hassio-config · GitHub ) since you also check for the largest value in the following automation: My-Hassio-config/max_peak_2.yaml at 56b473f09d59977c6f43c423e552cf6195614ef4 · gieljnssns/My-Hassio-config · GitHub . Doesn’t that check for the max value twice?
(I’m pretty new to HA so forgive me if I’m just missing stuff…)
So far I created:
a sensor to sum up my daytime and nighttime grid usage (the HomeWizard P1 meter tracks this separately)
a utility_meter to track quarterly kWh based on the above sensor
an input_number to store the max value of the current month (peak_current_month
Then I would guess it would be enough to just:
create a sensor (peak_current_quarter
) to return the peak kW (=the utility_meter * 4) (without comparing to the current max value at that point?)
and create an automation to set peak_current_month
to peak_current_quarter
if that is larger
And then I can show peak_current_month
and peak_current_quarter
on the dashboard.
DCSBL
(Duco)
January 3, 2023, 10:44pm
65
For HomeWizard Energy users: you can get the ‘official’ peak directly from the P1 meter, for now you can follow this issue and try to recreate it in configuration.yaml
. But I am working hard to get this added to the HomeWizard Energy integration natively. → Capacity tariff Flanders (Belgium) - Extra data-objects, telegram change · Issue #150 · DCSBL/python-homewizard-energy · GitHub
teranex
January 4, 2023, 11:01pm
66
You could have right, I never saw that.
Sharing my implementation here:
A utility meter, called kwartierverbruik, tracking the energy consumed over the 15 min interval.
A template sensor, that tracks the maximum peak up to that moment of the current month, it resets every month (by using an attribute):
template:
- sensor:
- name: "Kwartierpiek"
unique_id: "kwartierpiek"
state: >
{% set max_value = states.sensor.kwartierpiek.state|float(0) %}
{% set current_month = now().strftime('%m') %}
{% set last_reset_month = states.sensor.kwartierpiek.attributes.last_reset_month %}
{% if last_reset_month is defined and current_month != last_reset_month %}
{{ float(states.sensor.kwartierverbruik.state) * 4 }}
{% elif max_value is defined and max_value < 4 * float(states.sensor.kwartierverbruik.state) %}
{% else %}
{{ max_value }}
{% endif %}
attributes:
last_reset_month: >
{{ now().strftime('%m') }}
unit_of_measurement: "kW"
state_class: measurement
device_class: power
Vitruvius
(Vitruvius)
February 15, 2023, 9:16pm
69
@janmolemans Would you mind sharing your utility meter code as well? Thanks!
janmolemans
(Janmolemans)
February 22, 2023, 12:00am
70
the utility meter is not in code, but via the GUI: Settings → devices and services → helpers → utility meter.
This tracks the energy consumed over the 15 min interval and resets every 15 minutes.
hi @gieljnssns i implemented your code and everything calculates, but i have a p 1 meter thats says P1 meter Peak demand current month 5830W (5,83kW) but your readings are defferent (4,72) i must say i started your example a few days ago , the meter itselfs with the homewizard p1 integration is already counting from 26th februari, could that be the cause that those two numbers are not the same (because of a peak earlier then starting your implementation)?
i dont understand your macro part=
{% macro max(X, Y) -%} {{X|float if X|float > Y|float else Y|float }} {%- endmacro%}
{{ max(max_peak, peak) }}
are you willingly to explain it to me?
my ‘investigation(’ board added as image (and manualy put 5,83 in march peak )
The macro part is to define the max() function
max_peak = X
peak = Y
So the max() function
returns max_peak|float if max_peak|float > peak|float else peak|float.
That function returns always the biggest from the 2 values.
I hope you get it now.
now i get it!
any idea why my readings are off? (4,72 vs 5,8à ?
Can you check when there was that peak(5,8)?
by my meter p1 no :s it must happen before the integration with ha (a few days later because the port wastn activated yet-
