Utility meter doesnt reset to zero
I have 3 utility meters derived from 3 sensors, which are daily gas meters. Two of the sensors are direct readings from a gas meter, the last one is a calculated one.
sensor.gas49a = direct meter reading
sensor.gas49ab = direct meter reading
sensor.gas49b = the difference between sensor.gas49ab and sensor.gas49a
The derived utility meters should reset daily to show the daily gas usage.
Here is the template sensor for sensor.gas49b:
   sensors:
    gas_49ab:
     value_template: "{{states('sensor.p1_meter_3c39e727b94a_total_gas')}}"
     unit_of_measurement: mÂł
    gas_49a:
     value_template: >-
       {{ (states('sensor.huisbaasje_gas_today')|float|round(3))  }}
     device_class: gas
    gas_49b:
     value_template: >-
       {{ (states('sensor.gas_um_49ab')|float| round(2)) - (states('sensor.huisbaasje_gas_today')|float|round(3))  }}
     device_class: gas
However, the utility meter Gas_UM_49b resets daily but not to zero! Last night for example it reset to 2.8m3 ???
(by the way i used in the calculation for sensor.gas_49b the utility meter value sensor.gas_um_49ab but get the same results when using the sensor itself…)
Here is the utility meter which doesnt reset appropriately.
For reference, the other utility meters seem to work as expected and reset to zero.
I have the same issue, it’s really frustrating. Almost seems to be the last hours data that “sticks” and rolls over to the new day.
