Utility_meter has been removed in the 2022.9, help in converting code using `select`
Hi everyone!
Reading the breaking changes in the latest release (2022.9) i saw that utility_meter has been removed.
Now it should be used the select function, but I honestly dunno how to do that conversion.
utility_meter:
  total_energy_hour:
    source: sensor.total_kWh
    cycle: hourly
  total_energy_day:
    cycle: daily
    tariffs:
      - f1
      - f23
  total_energy_mth:
    cycle: monthly
    tariffs:
      - f1
      - f23
And then the usage in:
  - alias: Energy__Tariffa_F23_sera
    initial_state: on
      platform: template
      value_template: >-
        {{ states('sensor.time') == (states.input_datetime.energy_f23_start.attributes.timestamp | int | timestamp_custom('%H:%M', False)) }}
    condition:
      - condition: state
        entity_id: binary_sensor.giorni_lavorativi
        state: 'on'
    - service: utility_meter.select_tariff
        entity_id: utility_meter.total_energy_day
        tariff: f23
        entity_id: utility_meter.total_energy_mth
        tariff: f23
I would like to have some help on how to move this code to the select
Thanks in advance to everyone!
Here is my automation:
- alias: tarif_electricite
  initial_state: true
    - platform: time
      at: "07:00:00"
      variables:
        tariff: "pleines"
    - platform: time
      at: "23:00:00"
      variables:
        tariff: "creuses"
  condition:
    - condition: time
      weekday:
        - mon
        - tue
        - wed
        - thu
        - fri
    - service: select.select_option
        entity_id:
          - select.solar_exported_power_hourly
          - select.solar_exported_power_daily
          - select.solar_exported_power_monthly
          - select.solar_exported_power_yearly
          - select.solar_imported_power_hourly
          - select.solar_imported_power_daily
          - select.solar_imported_power_monthly
          - select.solar_imported_power_yearly
          - select.solar_house_consumption_hourly
          - select.solar_house_consumption_daily
          - select.solar_house_consumption_monthly
          - select.solar_house_consumption_yearly
          - select.solar_production_hourly
          - select.solar_production_daily
          - select.solar_production_monthly
          - select.solar_production_yearly
        option: "{{ tariff }}"
Look in Developer Tools → States. You should now have a select.total_energy_day and a select.total_energy_mth instead of utility_meter.total_energy_day and utility_meter.total_energy_mth respectively.
It is just a matter of using the select.select_option service instead of the utility_meter.select_tariff service. e.g.
  initial_state: on
    platform: template
    value_template: >-
  condition:
    - condition: state
      state: 'on'
      entity_id:
        - select.total_energy_day
        - select.total_energy_mth
      option: f23
hi @tom_l , thanks for your reply. I’ve checked and there are the select.total_energy_mth and select.total_energy_day as you said. I don’t understand how that is possible, give that i didn’t convert them.
Is there a way to have them natively converted in the code in select.total_energy_mth and select.total_energy_day?
Hi! I’m running into a problem with using select. The automation seemed to work but the value/state of the tariff is not. Here is an example of my automation that should have changed the tariff this morning. The automation did execute (checked the traces and execution time and for good measure I executed it manually as well)
alias: Tariff - Shoulder (morning)
description: ""
  - platform: time
    at: "07:00:00"
condition: []
      entity_id:
        - utility_meter.daily_energy
        - utility_meter.quarterly_energy
      option: shoulder
mode: single
And here are the current states of both utility meter tariffs that it should have changed.
Screenshot 2022-09-11 073846
Any ideas?
I am also in trouble because i have this code :
utility_meter:
  total_energy_hour:
    cycle: hourly
  total_energy_day:
    cycle: daily
    tariffs:
      - f1
      - f23
  total_energy_mth:
    cycle: monthly
    tariffs:
      - f1
      - f23
that is an utility_meter declaration afaik. If I remove it, on the restart HA complains with the following logs:
homeassistant    | Traceback (most recent call last):
homeassistant    |   File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 421, in async_render
homeassistant    |     render_result = _render_with_context(self.template, compiled, **kwargs)
homeassistant    |   File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1906, in _render_with_context
homeassistant    |     return template.render(**kwargs)
homeassistant    |   File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 1301, in render
homeassistant    |     self.environment.handle_exception()
homeassistant    |   File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 936, in handle_exception
homeassistant    |     raise rewrite_traceback_stack(source=source)
homeassistant    |   File "<template>", line 1, in top-level template code
homeassistant    |   File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1679, in forgiving_float_filter
homeassistant    |     return float(value)
homeassistant    | jinja2.exceptions.UndefinedError: 'None' has no attribute 'state'
homeassistant    |
homeassistant    | The above exception was the direct cause of the following exception:
homeassistant    |
homeassistant    |   File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 537, in async_render_to_info
homeassistant    |     render_info._result = self.async_render(variables, strict=strict, **kwargs)
homeassistant    |   File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 423, in async_render
homeassistant    |     raise TemplateError(err) from err
homeassistant    | homeassistant.exceptions.TemplateError: UndefinedError: 'None' has no attribute 'state'
homeassistant    | 2022-09-08 18:49:55.379 ERROR (MainThread) [homeassistant.helpers.template_entity] TemplateError('UndefinedError: 'None' has no attribute 'state'') while processing template 'Template("{{((states.sensor.total_energy_mth_f23.state | float) * (states.input_number.energy_cost_f23.state| float)) | round(2) }}")' for attribute '_attr_native_value' in entity 'sensor.energy_cost_mth_f23'
homeassistant    | 2022-09-08 18:49:55.381 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template("{{((states.sensor.energy_cost_mth_f1.state | float) + (states.sensor.energy_cost_mth_f23.state| float)) | round(2) }}")
And this because I have this:
    sensors:
      total_energy_mth:
        friendly_name_template: "Consumo mensile"
        icon_template: mdi:counter
        value_template: "{{((states.sensor.total_energy_mth_f1.state | float) + (states.sensor.total_energy_mth_f23.state | float)) | round(3) }}"
        unit_of_measurement: 'KWh'
I would like to the keep the logic, while replacing the utily_meter with something newer, does anyone can help me?
That’s why. The title of the post is incorrect. utility_meter has not been removed at all, - it’s still very much available.
All that has changed is how to select the tariff - an example of which is provided on the linked page.
I would however suggest that you update your template to this:
        value_template: "{{((states('sensor.total_energy_mth_f1') | float(0)) + (states('sensor.total_energy_mth_f23') | float(0))) | round(3) }}"
thanks a lot @mobile.andrew.jones for your help, really appreciated!
Here is your problem.
You need to change it to
        - select.daily_energy
        - select.quarterly_energy
As shown in your own screenshots
Sorry to bother you, I couldn’t resolve this problem.
Here below you can find my automation. The program doesn’t change tariffs between F1 and F2. It always show me F2 tariff.
Thank you so much in advance!
automation:
  • alias: Cambio Tariffa F1 con festivi
    initial_state: on
    platform: template
    value_template: >-
    {{ states(‘sensor.time’) == (states.input_datetime.f1_ora_inizio.attributes.timestamp | int | timestamp_custom(’%H:%M’, False)) }}
    condition:
    condition: and
    conditions:
    • condition: state
      entity_id: binary_sensor.giorni_fascia_elettrica
      state: ‘on’
    • condition: state
      entity_id: input_boolean.tariffa_weekend
      state: ‘on’
    • service: select.select_option
      entity_id: select.consumo_giornaliero
      tariff: f1
      entity_id: select.consumo_mensile
      tariff: f1
  • alias: Cambio Tariffa F2 con festivi
    initial_state: on
    platform: template
    value_template: >-
    {{ states(‘sensor.time’) == (states.input_datetime.f2_ora_inizio.attributes.timestamp | int | timestamp_custom(’%H:%M’, False)) }}
    condition:
    condition: and
    conditions:
    • condition: state
      state: ‘on’
    • condition: state
      state: ‘on’
      tariff: f2
    • service: select.select_optionf
      tariff: f2
  • alias: cambio tariffa f2 giorni festivi
    initial_state: ‘on’
    platform: state
    to: ‘off’
    condition:
    • condition: state
      state: ‘on’
      tariff: f2
      tariff: f2
  • alias: Cambio Tariffa F1 senza festivi
    initial_state: on
    platform: template
    value_template: >-
    condition:
    • condition: state
      state: ‘off’
      tariff: f1
      tariff: f1
  • alias: Cambio Tariffa F2 senza festivi
    initial_state: on
    platform: template
    value_template: >-
    condition:
    • condition: state
      state: ‘off’
      tariff: f2
      tariff: f2
I also have the same problem, but I think I have solved it try to change tariff in option
Thank you very much for your reply.
I made this change but nothing happened.
Could you please post all your Automation code? I think we have the same package.
Thank you!
Also check
  • service:
- id: '1665514557073'
  description: ''
    value_template: '{{ states(''sensor.time'') == (states.input_datetime.f1_ora_inizio.attributes.timestamp
      | int | timestamp_custom(''%H:%M'', False)) }}'
  condition:
  - condition: and
    conditions:
    - condition: state
      state: 'on'
    - condition: state
      state: 'on'
      option: f1
      entity_id:
      - select.consumo_giornaliero
      - select.immissione_giornaliero
      - select.produzione_giornaliero
      option: f1
      entity_id:
      - select.consumo_mensile
      - select.immissione_mensile
      - select.produzione_mensile
      option: f1
      entity_id:
      - select.consumo_annuale
      - select.immissione_annuale
      - select.produzione_annuale
  mode: single
  initial_state: 'on'
- id: '1665515052405'
  description: ''
    value_template: '{{ states(''sensor.time'') == (states.input_datetime.f2_ora_inizio.attributes.timestamp
  condition:
  - condition: and
    conditions:
    - condition: state
      state: 'on'
      attribute: workdays
    - condition: state
      state: 'on'
      option: f2
      entity_id:
      option: f2
      entity_id:
      option: f2
      entity_id:
  mode: single
  initial_state: 'on'
- id: '1665515503479'
  description: ''
  condition:
  - condition: state
    state: 'off'
      option: f1
      entity_id:
      option: f1
      entity_id:
      option: f1
      entity_id:
  mode: single
  initial_state: 'on'
- id: '1665515523866'
  description: ''
  condition:
  - condition: state
    state: 'off'
      option: f2
      entity_id:
      option: f2
      entity_id:
      option: f2
      entity_id:
  mode: single
  initial_state: 'on'
- id: '1665515541435'
  alias: Cambio Tariffa F2 giorni festivi
  description: ''
  - platform: state
    to: 'off'
  condition:
  - condition: state
    state: 'on'
      option: f2
      entity_id:
      option: f2
      entity_id:
      option: f2
      entity_id:
  mode: single
  initial_state: 'on'
hi guys
i’m using the updated package with select.select_option.
it was working months ago, but then i noticed that, even with the utility_meter changing tariff (f1 or f2) according to the schedule, the kHw gets added always to F2, but few random days (didn’t find any logic behind that)
It’s the same for daily, monthly and yearly counters.
