Although the sensor itself and the integration sensor are being updated, the utility meter stays at “0”. Is there anything missing or wrong in the config? The log file does not show any warnings or errors.
got it, was expecting a blue icon
Stupid question have you tried to start with a dash (-) like the other components?
Also you’ve not saved it under sensors have you?
scrap that, I think it’s because it’s looking for sensor.power_meter_integral when you name your sensor sensor.power_meter
try this and see if it works:
Thanks for that hint - actually it was something different but similar:
Using the sensor “sensor.power_meter” in the integration component creates a sensor called “sensor.sensor_power_meter_integral”. But I referenced “sensor.power_meter_integral” instead. That was the issue.
