Hi, I have a template sensor called “daily_savings” which records my £ savings per day every evening. I want to dashboard the total savings (the sum of all daily savings records). To do this, I created a simple utility meter, which has gone from 0 to 0.46 to 1.65, which is not representative of the values that the daily_savings sensor is recording. Can anyone please help me understand what I’m doing wrong here?
0.46 is the difference between your first value of 1.8 and second of 2.26.
1.65 is the difference between your first value of 1.8 and your third of 3.45.
How have you set up your utility meter? Looks like it’s not resetting daily as you intended.
Ah yes you’re right. I set up the utility meter via the GUI. Periodically resetting is turned on. Is Utility meter the right thing to give me a running total?
Hi Tom, I added this as the first picture. I am trying to get the meter to accumulate all of the daily values for my daily_savings sensor, to give me the “grand total”. Thank you
And restarted HA, waited a day, but the meter just says “Unavailable”. Is there anything else I need to set? I’d prefer to do it in the GUI but I could not find the delta_values option there. Thank you
There were a few things to fix. Thanks! Wasn’t aware of this menu.
This is what my utility meter looks like now. Is this expected? I was hoping for an accumulating line but it seems to reset to 0 some times. I think something’s no quite right. In the middle the daily_savings was unavailable but it then reset everything. I’ve now set periodically_resetting: false
