I have a problem with the monthly counters (for example the kwh counter that I spend per month) this month it did not return to zero, that is, it shows what I consumed so far and last month. I don’t know how to solve it and I don’t want to create all the sensors again
A quick solution would be to subtract the value from the previous month… but how do I change the value? If I go to developer tools and then state, I can change it but there it just goes back to the previous value
Dev tools > actions > utility meter calibrate
After calibrating, you may want to go to dev tools > statistics and adjust the outliers for that utility meter.
no it doesn’t take it, it always goes back to the previous one
Are you going to dev tools > states and changing it? That won’t work.
Go to dev tools > actions > calibrate utility meter.
Like this:
yes,
If I go there I assign the new value and it doesn’t change it!
Can you open a new tab and go to settings > system > logs. In another tab, calibrate your utility meter and see if there are any logs that show up.
If it’s not changing things, there’s something quite wrong.
