Utility meter setup from UI, how to add an offset of 5.5 hours?
I have created a utility meter using the UI, but I only have the option to add an offset with an integer number of days. I want to have an offset of 5.5 hours; I used to be able to do this via the configuration.yaml, but I cannot see how to do it with the UI.
Moreover, after having created the utility meter entity, if I try to modify it I only have limited options
How can I do it?
