Utility Meter - UI-based configuration and changes
thanks for making Utility Meter configurable via UI (helpers section). But how can I modify these settings later on, e.g. changing from delta to total_increment type?
Best,
Marcel
I can’t find this either! Did you find the solution yourself?
// Fredrik
True. If you have a Utility Meter helper and you try to modify the cron pattern for example you can not do this. I did not figure out how to edit such kind of helper. You are able to select only the input sensor
