Hi thee, I’m brand new to HA and have just worked out how to use the Utility Meter and got that working properly counting the integration of my solar PV production. I would also like to use Utility Meter to monitor my grid import/export. Is it possible to tell Utility Meter to only aggregate positive or negative values? I only have a single sensor for import/export which goes negative when importing and positive when exporting. I would also like to use this to measure battery charge and discharge energy, again from a single sensor with +/- values.
Second question is where Utility Meter stores my daily values when it resets at the end of every day!
Thanks in advance.
Hello.
Have you found a way? I would also be interested in doing this
me too, I need those negative values. statistics sensor works for last hour or so but not from midnight as I want
