I have a bunch of Tuya smart plugs with energy monitoring, set up with Tuya Local (the one from “make-all”). Among the sensors available, there is Power (in W) and Energy (in Wh). Energy is updated every half-hour with the energy consumption of the last half-hour. So to use it with HA’s Energy dashboard, I would need to make a running sum of that sensor. It seems to be what the helper Utility Meter was designed for, with delta values on.
It works well for loads that change all the time, because the energy consumption is different (even if slightly) every half hour, so Utility Meter helper picks up on the new value and add it to the running total. But for loads which are constant and long running, the Tuya Local Energy sensor has the same value every half-hour, and the Utility Meter helper ignore those value (it seems it thinks the sensor was simply not updated, while in fact it was updated but with the same value than before).
Is there any way to to “force” the update ? Either on a schedule (i.e. every half-hour, look at the sensor value and update the Utility Meter) or by detecting updates with the same value than before and treating them as real updates (and in that case, should the change be in the Utility Meter code and Tuya Local code)?
So far, I’m integrating Power instead (with the Integral helper), but it seems less reliable.
One way around it would be to feed your power sensor to the Riemann Sum integral helper to generate an ever increasing energy sensor. This can be done in the UI or YAML. Make sure to use method: left.
Yes, that’s what I’m doing in the meantime. But it would be reliable to use the on-device energy meter than integrating the power (for example, in case of very transient high power usage, that might not be registered by the power sensor)
The device probably performs an integration too, because what it will be measuring will be power.
Which will not matter too much for very short spikes. Whichever way it’s done will end up to be a function of resolution. Do you know how well the device deals with this? It’s best to check this assumption, because it may not matter.
Yes, you’re right, I should have checked the data before worrying. In the end, I found a resolution of 3 seconds for the Power sensor during short spikes. It’s good enough to just integrate that.
Here are all the details for the curious.
It seems to report power every one minute and 3 seconds (eh, why not) and energy every 29 minutes to 31 minutes. Here’s the last 24-hour data for a dehumidifier connected to one the Tuya plugs. The dehumidifier is either on (200W constant load, so 100Wh every half-hour) or off.
select
to_timestamp(s.last_reported_ts),
s.state,
(to_timestamp(s.last_reported_ts) - to_timestamp(sold.last_reported_ts)) as last_reported_ts_diff,
(to_timestamp(s.last_updated_ts) - to_timestamp(sold.last_updated_ts)) as last_updated_ts_diff,
(to_timestamp(s.last_changed_ts) - to_timestamp(sold.last_changed_ts)) as last_changed_ts_diff
from states s inner join states sold on(s.old_state_id=sold.state_id)
where s.metadata_id = XXX and now() - to_timestamp(s.last_reported_ts) < '1 day'
order by s.state_id desc
First the Energy sensor. There should be 48 lines (one every half-hour) but there are only 22
Timestamp
Energy
comment
2024-09-08 23:23:23.591 +0200
92
00:30:35.505596
00:30:01.547341
null
2024-09-08 22:52:48.086 +0200
16
00:29:54.983868
00:30:01.444915
null
2024-09-08 22:22:53.102 +0200
25
00:29:38.365291
00:30:01.476069
null
2024-09-08 21:53:14.737 +0200
80
00:30:23.037163
01:56:33.910489
null
device was on for two hours straight, so the next line (100Wh) should be repeated 4 times. Instead, there is a 1 hour 56 minutes “gap” in last_changed here
2024-09-08 21:22:51.699 +0200
100
01:56:17.41834
00:28:40.496219
null
and a 1 hour 56 minutes “gap” in last_updated here
2024-09-08 19:26:34.281 +0200
28
00:29:03.35405
00:30:01.403074
null
2024-09-08 18:57:30.927 +0200
88
00:29:53.631866
00:30:01.485157
null
2024-09-08 18:27:37.295 +0200
100
00:29:58.132772
00:28:19.626944
null
2024-09-08 17:57:39.162 +0200
63
00:28:08.376277
00:30:01.532578
null
2024-09-08 17:29:30.786 +0200
17
00:30:23.2228
00:30:01.453531
null
2024-09-08 16:59:07.563 +0200
12
00:29:41.548219
00:30:01.637751
null
2024-09-08 16:29:26.015 +0200
11
00:30:10.24083
00:30:01.514036
null
2024-09-08 15:59:15.774 +0200
1
00:30:13.911094
00:57:11.874087
null
2024-09-08 15:29:01.863 +0200
100
00:57:13.865532
11:51:37.292819
null
and here it was off for almost 12 hours (2W or 1Wh/half-hour consumption anyway). This line has a large last_changed_ts_diff
2024-09-08 14:31:47.998 +0200
1
11:51:07.968869
00:41:23.949532
null
and this one a large last_reported_ts_diff
2024-09-08 02:40:40.029 +0200
22
00:41:37.022479
00:30:01.478981
null
2024-09-08 01:59:03.006 +0200
100
00:29:57.519526
00:29:16.488079
null
2024-09-08 01:29:05.487 +0200
69
00:29:12.580562
00:30:01.686263
null
2024-09-08 00:59:52.906 +0200
34
00:30:07.357224
00:30:51.55735
null
2024-09-08 00:29:45.549 +0200
1
00:30:45.208748
00:00:06.005327
null
2024-09-07 23:59:00.340 +0200
27
00:00:28.189583
00:16:53.88813
null
And now the Power sensor. There are 399 lines for the same 24-hour period. I’m going to put some sample lines only.
Nominal situation, it reports power every 1 minute and 3 seconds:
Timestamp
Energy
2024-09-08 23:57:58.726 +0200
208.0
00:01:03.384975
00:01:03.386932
null
2024-09-08 23:56:55.341 +0200
207.6
00:01:03.386127
00:01:03.38292
null
2024-09-08 23:55:51.955 +0200
204.8
00:01:04.000283
00:01:03.895344
null
2024-09-08 23:54:47.954 +0200
207.9
00:01:03.282763
00:01:04.004766
null
2024-09-08 23:53:44.672 +0200
209.1
00:01:03.998324
00:01:08.399444
null
2024-09-08 23:52:40.673 +0200
206.9
00:01:08.504565
00:01:03.487604
null
2024-09-08 23:51:32.169 +0200
208.4
00:01:03.685843
00:01:03.594678
null
2024-09-08 23:50:28.483 +0200
206.8
00:01:03.292785
00:01:03.282886
null
2024-09-08 23:49:25.190 +0200
206.7
00:01:03.282035
00:01:03.381635
null
2024-09-08 23:48:21.908 +0200
206.1
00:01:04.000916
00:01:03.904194
null
2024-09-08 23:47:17.907 +0200
208.0
00:01:03.27463
00:01:03.678603
null
2024-09-08 23:46:14.632 +0200
205.5
00:01:03.701491
00:01:03.293378
null
And here is the 12-hour off period:
Timestamp
Energy
2024-09-08 14:07:58.800 +0200
198.2
00:01:03.288253
00:01:03.383096
null
2024-09-08 14:06:55.511 +0200
197.1
00:01:03.382172
00:01:03.38382
null
2024-09-08 14:05:52.129 +0200
192.8
00:01:03.286845
00:01:02.984811
null
2024-09-08 14:04:48.842 +0200
186.0
00:01:00.559992
12:28:13.872513
null
2024-09-08 14:03:48.282 +0200
0.0
12:28:12.758239
00:00:27.909855
null
2024-09-08 01:35:35.524 +0200
201.3
00:00:31.544755
00:01:03.282112
null
2024-09-08 01:35:03.979 +0200
200.9
00:01:03.179935
00:01:03.36821
null
2024-09-08 01:34:00.800 +0200
200.2
00:01:03.488474
00:01:03.09289
null
2024-09-08 01:32:57.311 +0200
200.0
00:01:03.072788
00:01:03.281923
null
But if necessary, the plug will report more frequently. Here is a different device (the server on which Home Assistant is installed). Normally, it uses about 36W of power, but during intensive tasks it can increase to about 100W. The Tuya plug will report the Power sensor as frequently as 3 seconds.
