Utility meters broken - or am I missing something?
To quote the doc:
Cycle reset occur at the beginning of the period (0 minutes, 0h00 hours, Monday, day 1, January).
Yet what I see in my meters is something like this:
As we can see - reset happens not at 00:00:00 (or “0h00 hours” for whatever that is supposed to express). This is bad if you rely on the period starting at zero and goes against the documented behavior.
Am I missing something obvious or should I file a bug?
Config:
        "entry_id": "abf460bb1f1e53e7b8a424c010089428",
        "version": 1,
        "domain": "utility_meter",
        "title": "Wasser Utility",
        "data": {},
        "options": {
          "name": "Wasser Utility",
          "source": "sensor.wasserverbrauch",
          "cycle": "daily",
          "offset": 0.0,
          "tariffs": [],
          "net_consumption": false,
          "delta_values": false
        "pref_disable_new_entities": false,
        "pref_disable_polling": false,
        "source": "user",
        "unique_id": null,
        "disabled_by": null
Check that the time on the pc you are viewing this on correct.
The web interface uses the browser time.
Time is correct (Both server and client are synced to ntp) though I wonder how a difference would come into play here. The stats are supposed to show the recorded value - how would a time difference between browser and server play any role here?
Edit: just noticed something:
1314815|2022-10-31 00:05:10.830649|2022-10-31 00:00:00.000000|||||0.0|5757.49|224
1314590|2022-10-31 00:00:10.802047|2022-10-30 23:55:00.000000|||||432.52|5757.49|224
The recorded value is correct. The UI displays a datapoint that just isn’t there. So the issue seems not to be with the Utility Meter but the graph display card pulling data points out of thin air.
The web browser you are using has the incorrect time.
If you say so…
I do. This issue has come up many, many times.
OK, enlighten me - how would that come into play here?
And again:
Bildschirmfoto 2022-10-31 um 12.24.47
HA just pulls the counter from the meter and only reset as the docs state, but the meter itself can also reset the counter, so maybe that is what occurs.
