In Energy Dashboard I can select the Liters template sensor, but not the utility meter.
Am I doing something wrong? If anyone can give me a hint that would be great.
How long has it been since you set up the utility meter? I think it can take a while for it to accumulate enough data to be selectable for the energy dashboard.
I wonder that the device_class “water” isn’t inherit from the source sensor. My electricity, gas, solar utility meters inherits the device_class from the source sensor.
How did you add the device_class? If I do I get an error:
Logger: aiohttp.server
Source: /usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py:403
First occurred: 21:02:23 (1 occurrences)
Last logged: 21:02:23
Error handling request
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 31, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 148, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/api/__init__.py", line 374, in post
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2012, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2049, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 599, in async_handle_core_service
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Invalid config for [utility_meter]: [device_class] is an invalid option for [utility_meter]. Check: utility_meter->utility_meter->energy_water_usage_liters_daily->device_class. (See /config/configuration.yaml, line 83).
Thanks for the help. Set the device_class via “customizing entities” didn’t work for me.
I had to set the device class in config/.storage/core.entity_registry and config/.storage/core.restore_state to get it working.
