Hi.
I am working on a DIY weather station and right now I am trying to add LTR390-UV sensor to it.
Everything is connected to NodeMCU ESP32 and that fine seems to be working fine (I think).
My ESPHome config for that sensor is as follows (I am using TCA9548A I2C multiplexer):
While I am plying with the config everything currently sits outside on my garden table. It is a fairly gray day (sky is covered in clouds) - according to various sources the UV Index should be between 3-4.
My Sensor is reporting the following values:
Ambient Light: 121,012
Light: 12,106 lux
UV: 164
UV Index: 0.07217
The ambient light/light values seems OKish as far as I can tell looking at various online sources.
However the UV and UVI values are way off what is reported right now for my location.
The sensor is not covered with anything - that is another thing I need to figure out - what sensor cover to use so it does not affect the measurements.
Any ideas why the values are so wrong?
Any one out here have any experiences with this sensor?
For the glass you want Far UV Grade Fused Silica Quartz. This is frequently sold in 30mm squares. I have one and it does not affect the readings from quick testing. My regular windows reduce UVI reading by one decimal place (0.14 → 0.014).
Plan on installing this in a weather station so the readings will probably change.
I have the same weird index values. And I think I figured out the issues. I opened an issue in the esphome github, the details are there:
Until it is fixed in the esphome depository, here are the possible workarounds:
workaround 1:
The resolution config does not work, so leave it at 18-bit default.
The UVI calculation depends on the resolution config and gain config, so calculate your own using this formula:
UVI = ( uv / 2300 * wfac ) * 4 * ( 18 / gain )
The first part is the original formula.
The x 4 is to adjust for being at default 18-bit resolution instead of 20-bit.
The x 18 / gain is to adjust for actual gain configured vs x18 gain assumed in the original formula.
workaround 2:
Use the esphome external components method to override the ltr390 component.
Set up the external component by downloading the ltr390 files from the esphome github, you should get 4 files in the ltr390 directory. Overwrite the ltr390.cpp file by the file I attached in the opened issue above (the attached file should be renamed to ltr390.cpp).
Does this lamda look right?
Also, are the wfac and gain correct assuming I’m not changing any of the defaults?
I’m still getting UVI values about 1/4 what is published for my zip code.
I’m not having any luck receiving data from my Gravity LTR390-UV. It’s connected to a ESP32ThingPlus using the default pins SDA: GPIO23 and SCL: GPIO22.
I’m at a point where I at least get the device discovered. I have experimented with a few different approaches using code others have found works. What should I expect to see? has anyone any suggestions on how I could test to see if it’s even functional. beginning to think I’ve got a dud sensor.
[14:13:02][C][i2c.arduino:054]: SDA Pin: GPIO23
[14:13:02][C][i2c.arduino:055]: SCL Pin: GPIO22
[14:13:02][C][i2c.arduino:056]: Frequency: 50000 Hz
[14:13:02][C][i2c.arduino:059]: Recovery: bus successfully recovered
[14:13:02][I][i2c.arduino:069]: Results from i2c bus scan:
[14:13:02][I][i2c.arduino:075]: Found i2c device at address 0x1C
so, to have it right, shall 2300 in the formula ( ((id(ltr390_uvs).state * wfac) / 2300) * 4 * ( 18 / gain )); be replaced by 1400, so ( ((id(ltr390_uvs).state * wfac) / 1400) * 4 * ( 18 / gain ));?
