Honestly it would be nice if the config was checked automatically when you hit the restart button, and then present the user an “are you sure” warning.
If it’s misconfigured, the system generally won’t come back up and will make it harder to fix the problem.
to my knowledge it does check automatically, also what i’ve seen others say … i.e. i actually seen it my self, 1 time that i didn’t performed a check … it shows warning and not able to restart, with note saying check config
I am old and reluctant to change. Yes, I’ve griped in the past and my complaint has almost always been addressed in the Breaking Changes. Overall, I am pleased with the long-term improvements. I started using Home Assistant before Lovelace. I resisted that change as well. But the farther I get away from YAML, the more I like the UI improvements.
The configuration is indeed checked when rebooting, but there is a flaw: Sometimes the configuration check succeeds, while all the same the persistent notification area shows a message saying there’s an error preventing some yaml file from loading. I assume that would mean the system reboots nontheless on account of the check saying it is ok.
Just had it happen to me yesterday when the template sensors were broken but the reboot went through. It did come back alive with a lot of template sensors unavailable, so it wasn’t critical. But it was annoying as I even did the check but failed to spot the notification (left menu was hidden).
This is the important part. Your system would likely have passed the old “Check Config” as well since, as I understand, it doesn’t check the code quality- just the syntax. A misspelled entity name in a properly formatted YAML file will pass. Trust me, I’ve tested this.
Yes right, i actually didn’t make any changes in config.yalm, i just removed an integration … which i forgot there was a reference to in config.yaml … so i got a little “chocked” seeing the pop-up " Failed"
Id did come alive, but is was a syntax error causing the entire templates.yaml to fail loading, so as far as home automation goes a huge chunk was broken. I would expect an error like that to show up as a bad config, not just a notification.
Am I looking in wrong places?
(Also - when first frustration passed, reread what I wrote and decided to change topic title Not antagonizing the community might prove more constructive in the long run! )
Where did you get this “binary website update” sensor from ?
( I mean looking for core, supervisor, os, integration updates , is not “Optimalt”, when it says “Home Assistant Website Update Available” )
I believe that this sensor is created by the version integration, and that “website” refers to this method of getting version info Version - Home Assistant
In other words, I don’t think it relates to the HAOS version at all, but is the core version.
That’s so strange. I very specifically remember the reddit thread on this which was quite popular with people being absolutely lost with the proposed design changes and hating it. It does seem like most of what was originally proposed was not implemented which is good, but from the feedback that was posted publicly, I have a hard time seeing they were “mostly neutral or positive”.
In this case, I have to side with OP. I get the push towards mobile, but this specific case feels like a step backwards.
