V&M Assistance ThirdReality Installation problems
I have encountered a problem in getting the new Voice & Microphone device brought into my homeassistant green. I have followed the git hub instructions several times without success. Here are the instructions I followed. Any advice would be appreciated.
How to connect wifi
  1. You need to install the iOS or Android version of the Home Assistant app first.
  2. Make sure the speaker is in a yellow blinking state.Otherwise, please try factory reset. (Press and hold the Home button for 15 seconds, then release it after you hear the prompt sound.)
  3. Open the Home Assistant app on your phone.Go to Settings → Devices & services and under Discovered, you should see the device as “3RSPK-XXXXX Improv via BLE”.
  4. Enter your Wi-Fi SSID and password. Only 2.4 GHz networks are supported.
  5. A few seconds after the Wi-Fi connection is successful, the speaker will play “Your device is ready to connect to Home Assistant.” At that point, you can proceed to the next step.
I had the same issue. see the post i made if it applies to you.
