V0.101.2 case sensitive
I upgraded to v0.101.2.
My previous defined scene doesn’t work anymore.
With following definition of my lights
light:
  - platform: mqtt
    name: "Lamp Peter Frans 01"
    state_topic: "hass/living/lamp_pf_01"
    command_topic: "hass/living/lamp_pf_01"
    payload_on: "1"
    payload_off: "0"
    retain: true
  - platform: mqtt
    name: "Lamp Peter Frans 02"
    state_topic: "hass/living/lamp_pf_02"
    command_topic: "hass/living/lamp_pf_02"
    payload_on: "1"
    payload_off: "0"
    retain: true
The following scenes DO NOT work:
scene:
  - name: Lamp Peter Frans s1
    entities:
      light.Lamp_Peter_Frans_01: off
      light.Lamp_Peter_Frans_02: off
  - name: Lamp Peter Frans s2
    entities:
      light.Lamp_Peter_Frans_02: on
  - name: Lamp Peter Frans s3
    entities:
      light.Lamp_Peter_Frans_01: on
  - name: Lamp Peter Frans s4
    entities:
But following scenes DO work:
scene:
    entities:
      light.lamp_peter_frans_01: off
      light.lamp_peter_frans_02: off
    entities:
      light.lamp_peter_frans_02: on
    entities:
      light.lamp_peter_frans_01: on
    entities:
See the subtile difference in cases.
For some reasion, I HAVE to refer to the lights with lowercases, altough their definition is with uppercases…
I think this was introduced in V0.101.2…
Not a big deal if you know, but it took me a while figuring out why my home assistant did’nt startup anymore. Weird error messages in log:
Nov 04 22:43:07 deb-17 hass[6674]:   File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/auth/__init__.py", line 123, in async_get_user
Nov 04 22:43:07 deb-17 hass[6674]:     return await self._store.async_get_user(user_id)
Nov 04 22:43:07 deb-17 hass[6674]:   File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/auth/auth_store.py", line 72, in async_get_user
Nov 04 22:43:07 deb-17 hass[6674]:     await self._async_load()
Nov 04 22:43:07 deb-17 hass[6674]:   File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/auth/auth_store.py", line 289, in _async_load
Nov 04 22:43:07 deb-17 hass[6674]:     await self._async_load_task()
Nov 04 22:43:07 deb-17 hass[6674]:   File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/auth/auth_store.py", line 296, in _async_load_task
Nov 04 22:43:07 deb-17 hass[6674]:     self._store.async_load(),
Nov 04 22:43:07 deb-17 hass[6674]: concurrent.futures._base.CancelledError
Nov 04 22:43:07 deb-17 hass[6674]: Config directory: /home/homeassistant/.homeassistant
Is this a bug?
Kind regards,
Bart
What version did you upgrade from? Entities names have been required to be lower case for quite awhile now.
Hello @freshcoast,
Thanx for pointing me to documentation.
I upgraded from previous version, wich means
  • there was a “bug” in previous version in a way that you could use Uppercase there
  • I made some modifications in my scenes, and I just reloaded the scenes without rebooting home-assistant. Maybe in that case Uppercase is accepted…
I suppose it’s the second case…
However, the biggest bug is that I didn’t read the documentation first :slight_smile:
kind regards,
Bart
