V0.113 - Anybody else with issues with the more-info-card
Is anybody else experiencing any issues with the more-info-card?
I installed it via HACS and it worked fine until V0.112.x but after upgrading to V0.113 and V0113.1 it only displays the card headers, nothing else.
P.S.:
Downgraded to V0.112.4 where the cards displayed fine again and re-upgraded to V0113.1 where they are not showing properly.
Yes, having the same problem. It’s to do with changes in 0.113 to how more-info is called in Lovelace.
I see you’ve added a comment to the reported issue on GitHub, but there’s also another report:
Something similar affected pop-ups in the browser-mod component from the same author (thomasloven) and he fixed it really quickly. so I guess he’ll get round to it when he can.
Thanks for the confirmation, so it’s not just my ‘special’ setup.
Is there any quick/dirty alternative to the more-info-card? I’ve found it super helpful for a robot vacuum as there are a ton of controls which used to display great using this in Lovelace
I figured out the my more-info-card still had an issue after the upgrade to the latest version in HACS because, at one time, it was installed manually so it still referred to the wrong, old js file.
Once I changed that, the more-info-card worked fine again.
Thanks - hadn’t thought to check!
sorry, how did you fix/check this and resolve it?
