I’ve been having a problem with the Tesla integration for the past few builds and it seemed that 2020.2.3 was supposed to address this by adding oauth3 but instead of saying cannot connect it now just fails outright fails with unknown error. Is anyone else still having issues with the Tesla integration?
Log Details (ERROR)
Logger: aiohttp.server
Source: components/tesla/config_flow.py:157
First occurred: 7:06:51 AM (2 occurrences)
Last logged: 7:10:50 AM
Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 172, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 169, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 60, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 106, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 155, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 213, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/tesla/config_flow.py", line 57, in async_step_user
info = await validate_input(self.hass, user_input)
File "/usr/src/homeassistant/homeassistant/components/tesla/config_flow.py", line 157, in validate_input
(config[CONF_TOKEN], config[CONF_ACCESS_TOKEN]) = await controller.connect(
File "/usr/local/lib/python3.8/site-packages/teslajsonpy/controller.py", line 268, in connect
cars = await self.get_vehicles()
File "/usr/local/lib/python3.8/site-packages/backoff/_async.py", line 133, in retry
ret = await target(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/teslajsonpy/controller.py", line 357, in get_vehicles
return (await self.__connection.get("vehicles"))["response"]
File "/usr/local/lib/python3.8/site-packages/teslajsonpy/connection.py", line 78, in get
return await self.post(command, "get", None)
File "/usr/local/lib/python3.8/site-packages/teslajsonpy/connection.py", line 96, in post
self.code = await self.get_authorization_code(
File "/usr/local/lib/python3.8/site-packages/teslajsonpy/connection.py", line 372, in get_authorization_code
code_url = URL(resp.history[-1].url)
IndexError: tuple index out of range
