V2021.5.0: how to remove integration when not available
In the latest version, the tree dots are missing on an integration that is not loaded.
In my case: I recently fully switched from IKEA to Zigbee2MQTT and turned my IKEA hub off to have no interference. Now I wanted to remove the integration, but this was not possible anymore:
FYI: I turned my IKEA bridge on, restarted hass and I could remove the integration. So no big issue for me, but what If I could not turn it on anymore?
grtz
B
Most likely you would have to edit the .storage files.
Now, isn’t that convenient.
Especially since we aren’t supposed to be editing those files.
same issue here. (btw the nas is running perfectly, only not in HA)
where in the .stoarge file can i edit this?
EDIT: never mind, I’d lost a SMB connection with the NAS, therefor it did not load in HA.
Hi I have the same issue with my Synology integration, I need to remove it and I don’t have the three dots . I can see the .storage but not sure where to go from there.
thanks in advance
You open an issue with the integration developer. For core issues that’s here:
