V4.0 Climate Control via DEW POINT COMFORT - Triggers - Door, Presence, TTS, NodeRED
This flow uses Outside Dew Point Temperature to control any Climate Entity through Home Assistant.
Tested on TADO Smart AC Control V3+ this does not require a paid subcription to TADO.
- Home and Away Presence Sensing
- Door and Window Open Detection
- Uses Outside Dew Point to set Heating, Comfort or Cooling Programs
- Uses Indoor Dew Point to set Heating, Drying, Cooling or OFF Modes
- Heat Boost Mode if the Dew Point is low in a room
- Sets A/C to OFF or Economy Setting when set room temperature is reached
- Avoids sending commands to A/C for the same mode, allowing idle state.
- Activates Dehumidifier or Drying Mode, to improve Dew Point Comfort and reduce humidity
- Coloured Light Notifications to signify A/C mode
Dew point control is a method of regulating the amount of moisture in the air to maintain a comfortable room temperature. It’s important for underfloor cooling systems and can help reduce energy costs.
How it works
- Dew point control regulates the amount of condensation that forms when warm air meets cold surfaces.
- A low dew point makes the air feel drier, while a high dew point makes it feel more humid.
- Air conditioning removes moisture and heat from the air, which lowers the dew point.
How to control dew point
- Use a dehumidifier or humidifier to control the humidity level.
- Ventilate the home properly. (Ventilation control coming in the next update)
- Use a dew point sensor to calculate a rooms from temperature and humidity.
- Use a hygrometer to measure humidity.
Benefits of dew point control Reduces energy usage, Prevents heat loss, Helps save money on heating bills, and Ensures that your home remains comfortable all year round.
REQUIREMENTS
- node-red-contrib-time-of-day
- Node-RED Companion Integration
- A way to calculate Dew Point for each room that has a Temperature and Humidity Sensor. Dew Point
- NodeRED Flow
FEATURES
SET TADO HOME AND AWAY SWITCH
(Controlled in Flow and Dashboard Switch)
- Home and Away Switch Triggers
- Trigger when persons in zone.home are more than 1
- Poll zone.home more that one every 5 minutes, catches if a door or manual input has turned off the home switch
- Switch exposed to Home Assistant to allow manual control and display notifcations
- Switch sets TADO Preset Modes, Home and Away (In the Tado App you can set different smart schedules for Home and Away Modes)
- NOTE: There seems to be some limitations with sending dry mode via NodeRED or HA to my heat pumps. Setting in the TADO App works.
- I have set my TADO Schedule Home Mode to DRY for both Heat Pumps.
- I have set my TADO Schedule Away Mode to OFF for both Heat Pumps.
- This Switch is what is activated in the flow.
- Sends msg.topic: check so TTS does not activate everytime there is a change
ACTIVATION
- Check every 5 Minutes Topic: check
- Turns ON Home and Away Switch, only if TADO Mode is Home and Contact Sensors are OFF (Doors Closed)
- If TADO Mode Home and Contact Sensors are ON (Doors Open) turns OFF A/C
- Contact Sensors CLOSED 15sec - Topic:door
- When all Contact Sensors are OFF (Doors Closed) Activates A/C
- Sends msg.topic: door so TTS does activate between set times
- Contact Sensors OPEN 2 Mins - Topic:door
- When all Contact Sensors are ON (Doors Open) Turns OFF A/C
CHECK DEW POINT
- Check Outside Dew Point to Set Program
- Dewpoint (<12.79 - Dry)(12.8-15.4 - Comfortable)(>15.5 Humid)
- Activates Programs based on Outside Dew Point Comfort, which is a combination of temperature and humidity.
- Check Inside Dewpoint to Set Heating Program
- Dewpoint (<10.0 - Dry)(10.1-12.79 - Pleasant)(12.8-15.4 - Comfortable)(15.5-18.39 - Sticky)(>18.4 - Muggy)
- Sets the modes of the heat pump based on the above Dew Point thresholds
- There is 3 programs Heating, Comfort and Cooling
The below chart is what the comfort values are based off and can vary slightly depending on your climate.
MODES
Active Time
- Set the time you want the heating or cooling to be active, if false goes to sets the Heat Pump to a lower more power efficient setting (auto=TADO Smart Schedule)
Don’t set if already Set - As the dewpoint is checked every 5mins, this ensures your A/C handles the set temperature. Avoids multiple ON and Mode commands that keep your A/C running, unnecessarily.
HEAT BOOST MODE, HEAT 23, HEAT 21, HEAT 19 (TTS Topic: door)
- Sets HVAC mode to heat
- Sets Temperature to 25°C, 23°C, 21°C, 19°C
- HA Thermostat card will say Heating
- NOTE: Not recommended to send swing or fan mode changes, A/C will default to auto and set swing without them)
- *NOTE: The difference in height/temperature from my TADO V3+ thermostat is about 3°C, keep this in mind when setting heat
- If between set times and msg.topic: door TTS will activate
TADO SCHEDULE DRY MODE (TTS Topic: door)
- Sets HVAC to home
- Sets mode to auto via (auto=TADO Smart Schedule)
- HA Thermostat card will say Drying
- NOTE: This uses the temperature or mode settings from your TADO Smart Schedule in my case I use it for the dry mode
OFF MODE (TTS Topic: door)
- Sets HVAC to off
- HA Thermostat card will say Off
COOL MODE (TTS Topic: door)
- Sets HVAC to cool
- Sets Temperature 26°C
- HA Thermostat card will say Cooling
- NOTE: The difference in height/temperature from my TADO V3+ thermostat is about 3°C, keep this in mind when setting cool temperature
DEHUMIDIFER
- Turns ON and OFF Dehumidifier with smart plug.
- NOTE: Drying the air reduces dewpoint temperature
AIR CONDITIONING LIGHT NOTIFICATIONS
- Activates a status bar lights depending on the mode that is active
