VA ESP32 Code from Youtube. Everything Too fast - needs a mic mute or a delay
Can anyone help. I re-created the code from the competition youtube video and made a few adjustments. One of which is to use my Sonos Media player speaker to play the responses.
Instead of useing a “boing” sound for on_wake_word_detected: i tried using the word “Yes?” as a response. The problem is that on_listening: is so fast, it detects the word “yes?” as part of the intent and fails (obviously because “yes turn on the lights” is something it cant execute.
Is there a way to either mute the microphone for a second when on_listening: OR slow down on_listening: so that it picks up audio AFTER the word “yes?”
For those interested - code from the video is below with my own modifications in the light area and to get the responses playing on a media player of your choosing.
substitutions:
  voice_assist_idle_phase_id: '1'
  voice_assist_listening_phase_id: '2'
  voice_assist_thinking_phase_id: '3'
  voice_assist_replying_phase_id: '4'
  voice_assist_not_ready_phase_id: '10'
  voice_assist_error_phase_id: '11'
  voice_assist_muted_phase_id: '12'
esphome:
  friendly_name: HA VOICE ASSISTANT
  on_boot:
    priority: 600
    then:
      - script.execute: control_led
      - delay: 30s
      - if:
          condition:
            lambda: return id(init_in_progress);
          then:
            - lambda: id(init_in_progress) = false;
esp32:
  board: esp32dev
  framework:
    type: esp-idf
esp_adf:
external_components:
  - source: github://pr#5230
    components:
    - esp_adf
    refresh: 0s
logger:
api:
  encryption:
    key: "whateveryourwanthere"
  on_client_connected:
  on_client_disconnected:
ota:
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.1.2
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  on_connect:
  on_disconnect:
  ap:
    ssid: "Esphome-Web-888888"
    password: "blahblahblah"
captive_portal:
light:
  - platform: esp32_rmt_led_strip
    rgb_order: grb
    pin: GPIO15
    num_leds: 15
    rmt_channel: 0
    chipset: WS2812
    default_transition_length: 0s
    effects:
      - pulse:
          transition_length: 1s
          update_interval: 1s
          min_brightness: 50%
      - pulse:
          update_interval: 1s
          min_brightness: 50%
      - addressable_rainbow:
          speed: 10
          width: 50
      - addressable_twinkle:
          twinkle_probability: 5%
          progress_interval: 4ms
      - addressable_scan:
          move_interval: 100ms
          scan_width: 4
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO25
    i2s_bclk_pin: GPIO26
microphone:
  platform: i2s_audio
  adc_type: external
  pdm: false
  i2s_audio_id: i2s_in
  i2s_din_pin: GPIO34
voice_assistant:
  microphone: external_microphone
  use_wake_word: true
  noise_suppression_level: 4
  auto_gain: 31dBFS
  volume_multiplier: 8.0
    - homeassistant.service:
        service: tts.speak
          media_player_entity_id: media_player.your_meediya_playa
          message: Yes?
          entity_id: tts.piper
    - lambda: id(voice_assistant_phase) = ${voice_assist_listening_phase_id};
  on_listening:
  on_stt_vad_end:
    - lambda: id(voice_assistant_phase) = ${voice_assist_thinking_phase_id};
  on_tts_start:
        service: tts.speak
          message: !lambda 'return x;'
    - lambda: id(voice_assistant_phase) = ${voice_assist_replying_phase_id};
  on_tts_end:
    - lambda: id(voice_assistant_phase) = ${voice_assist_idle_phase_id};
  on_error:
    - if:
        condition:
          lambda: return !id(init_in_progress);
        then:
          - lambda: id(voice_assistant_phase) = ${voice_assist_error_phase_id};
          - delay: 1s
          - if:
              condition:
                switch.is_on: use_wake_word
              then:
              else:
                - lambda: id(voice_assistant_phase) = ${voice_assist_muted_phase_id};
    - if:
        condition:
        then:
          - voice_assistant.start_continuous:
        else:
    - lambda: id(voice_assistant_phase) = ${voice_assist_not_ready_phase_id};
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    on_turn_on:
      - if:
          condition:
          then:
            - if:
                condition:
                  not:
                    - voice_assistant.is_running
                then:
                  - logger.log: XXXXXXXXXXXXX VA start_continuous XXXXXXXXXXXXXXX
    on_turn_off:
      - if:
          condition:
          then:
            - voice_assistant.stop
            - logger.log: VA stopped
    optimistic: true
    on_turn_on:
      - logger.log: XXXX VA start_continuous XXXX
    on_turn_off:
      - logger.log: XXXX VA STOP XXXX
globals:
  - id: init_in_progress
    type: bool
    restore_value: no
    initial_value: "true"
  - id: voice_assistant_phase
    type: int
    restore_value: no
    initial_value: ${voice_assist_not_ready_phase_id}
script:
  - id: control_led
    then:
      - if:
          condition:
          then:
            - if:
                condition:
                  wifi.connected:
                then:
                  - if:
                      condition:
                        api.connected:
                      then:
                        - lambda: |
                            switch(id(voice_assistant_phase)) {
                              case ${voice_assist_listening_phase_id}:
                                id(led).turn_on().set_rgb(1,0,0).set_brightness(1).set_effect("Slow Pulse").perform();
                                break;
                              case ${voice_assist_thinking_phase_id}:
                                id(led).turn_on().set_rgb(0,0,1).set_effect("Fast Pulse").perform();
                                break;
                              case ${voice_assist_replying_phase_id}:
                                id(led).turn_on().set_rgb(0,0,1).set_effect("Rainbow").perform();
                                break;
                              case ${voice_assist_error_phase_id}:
                                id(led).turn_on().set_rgb(1,1,1).set_effect("Fast Pulse").perform();
                                break;
                              case ${voice_assist_muted_phase_id}:
                                id(led).turn_on().set_rgb(1,1,0).set_effect("none").perform();
                                break;
                              case ${voice_assist_not_ready_phase_id}:
                                id(led).turn_off().perform();
                                break;
                              default:
                                id(led).turn_on().set_rgb(1,0,0).set_brightness(1).set_effect("Scan").perform();
                                break;
                      else:
                        - light.turn_off:
                else:
                  - light.turn_off:
          else:
            - light.turn_on:
                blue: 0%
                red: 0%
                green: 100%
                effect: "Fast Pulse"
So I gave up on this project mainly because of this issue back in 2024.
I have a real world use case for this and am looking at picking it back up.
I cant believe that NOBODY encountered this issue themselves???
All I want to do is replace the “boing” sound with the word “Yes” from a whole house SONOS “in ceiling” system (very Tony Stark) and not have the satellite think it was a human.
The only way I can think of circumventing this issue is to connect the mic power supply to a GPIO and turn the mic off and then back on after a delay based on_wake_word_detected: so that the mic is muted for a while.
I did make a issue request some time back but it was ignored.
