Hi am a newbie in this and would like some help to start off. Been reading but not sure how to start. After a few I will get the hang of things.
I have a DSC alarm with envisialink4 .
Last night I managed to connect home assistant to my different zones. (baby steps but got it to work)
I see the disarm /arm , My house keypad and all my zones I configured in the overview page in top row.
What I would like to do is set up a vacation mode when not at home so lights go on and off at a certain time. This can be triggered by armed and disarmed mode of my alarm if it is possible.
If someone could guide me in my configuration this is what I would like it to do.
When system is armed in away mode not home mode between sunset and midnight, I would like for my 7 different lights to go on and off in a random mode as to create a feel of presence in the home.
I would like to also have 1 and/or 2 lights at the same time.
I have seen some scripts with vacation mode here but would need help to integrate it with my alarm system if possible.
Ok playing around and have some issues.
I set up a group and it works
Now using vacation mode based on script I found here for alarm and I am getting this error when I do a configuration validation after adding the Random lights on while sunset and armed away script
Error loading /config/configuration.yaml: while parsing a block mapping in “/config/configuration.yaml”, line 1, column 1 expected <block end>, but found ‘-’ in “/config/configuration.yaml”, line 150, column 1
I indicated which one is line 150
Here is my configuration file with sensitive information replaced by 0’s
Also some questions in bold
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 0
longitude: 0
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: UTC
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Sensors
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
tuya:
username: "0000"
password: "0000"
country_code: "1"
august:
login_method: email
username: "0000"
password: "0000"
envisalink:
host: 192.168.2.000
panel_type: "DSC"
user_name: "0000"
password: "0000"
code: "0000"
port: 4025
evl_version: 4
keepalive_interval: 60
zonedump_interval: 30
timeout: 10
panic_type: Police
zones:
1:
type: 'door'
2:
type: 'door'
3:
type: 'door'
4:
type: 'motion'
5:
type: 'motion'
6:
type: 'motion'
7:
name: 'Motion Basement'
type: 'motion'
13:
type: 'door'
14:
type: 'garage_door'
16:
name: 'Smoke Detector'
type: 'smoke'
partitions:
1:
light:
- platform: group
entities:
- light.53411381807d3a59486b #bedroom
- light.53411381807d3a59491c #family room
- light.53411381807d3a596f8c #fireplace lights
- light.53411381807d3a597774 #kitchen ceiling
- light.53411381807d3a5972d7 #kitchen Island
- light.53411381807d3a597131 #living room ceiling lights
## Random lights on while sunset and armed away
- alias: Random Away Lights **this is line 150**
initial_state: True
hide_entity: False
- platform: time
minutes: '/30' **What is the 30 for? isn't it triggerd by sunset below? or is this the random of every 30 minutes switch light?**
seconds: 00
condition:
- condition: state
entity_id: alarm_control_panel.ha_alarm
state: 'armed_away'
- condition: sun
after: sunset
- delay: "00:{{ '{:02}'.format(range(5, 11) | random | int) }}:00"
- condition: state
state: 'armed_away'
- service: homeassistant.toggle
data_template:
entity_id: "{{ state_attr('group.away_lights','entity_id') | random }}"
## Sunrise Random Lights Off
- alias: Random Lights Off Sunrise
initial_state: True
hide_entity: False
- platform: sun
event: sunrise **How do I change this to end at midnight instead of sunrise?**
condition:
- condition: state
state: 'armed_away'
- service: homeassistant.turn_off
entity_id: group.away_lights
## Alarm Disarmed Random lights Off
- alias: Random Lights Off Disarmed
initial_state: True
hide_entity: False
- platform: state
to: 'disarmed'
You have 1 automation section that specifically calls out creating automations in a separate automations.yaml file.
Then you proceed to try to add automations at line 150 outside the any section when they should be in an automation section. I.E. automations.yaml. (which you call out in line 69: automation: !include automations.yaml).
You need to do 1 of the following:
Move your automations into your automation.yaml files.
Create a second automation section at line 148 named automation 2: Although you may run into issues with this method.
Thanks for the reply but I am a total noob not sure how to this. Don’t know what to transfer exactly to the automation file?
Can you give me example so I can just copy paste
Is there a way I can just leave all in the configuration file and correct errors from there?
did you remove what you copied in the other area? Not for nothing but you are giving little to no information here.
Show the error and the full configuration. Some of this is going to have to be understood by you. If the error contains a line # and a position number, look at that line and position. That’s where your error is
I have taken out of configuration file and pasted only in automations.
Now no more error let’s hope it works.
Thanks for your help and patience so far. I am learning as I go
BTW
Sorry my full configuration is in my first post. and the error was stated there. Here it is again.
I have the automation listed above in my automation yaml
I have in groups my All lights group
I have in configuration my alarm system which the configuration file is listed above
In home assistant overview I see tile with all lights listed and all other lights below
I have an automation tile which has listed
Random away lights
Random lights off disarmed
Random lights off sunrise
All above 3 have the blue switch to on
But my issue is if I arm system after sunset the lights are not going on.
If I manually turn on light in the away group and disarm the system or wait till sunlight the lights don’t turn off.
If I manually trigger the Random All lights nothing happens
If I manually turn on light and disarm system and manually trigger the Random lights off disarmed or the Random lights off sunrise then the lights will turn off.
Why is this not working when conditions are met ? What am I doing wrong?
homeassistant:
latitude: 0
longitude: 0
elevation: 0
unit_system: metric
time_zone: UTC
introduction:
frontend:
config:
# http:
updater:
discovery:
conversation:
history:
logbook:
map:
# Track the sun
sun:
# Sensors
- platform: yr
# Text to speech
tts:
- platform: google
# Cloud
cloud:
tuya:
username: "0000"
password: "0000"
country_code: "1"
envisalink:
host: 192.168.2.???
panel_type: "DSC"
user_name: "????"
password: "????"
code: "0000"
port: 4025
evl_version: 4
timeout: 10
panic_type: Police
zones:
1:
type: 'door'
2:
type: 'door'
3:
type: 'door'
4:
type: 'motion'
5:
type: 'motion'
6:
type: 'motion'
7:
type: 'motion'
13:
type: 'door'
14:
type: 'garage_door'
16:
type: 'smoke'
partitions:
1:
It’s not going to trigger immediately, you have a 5- 11 minute delay coupled with a 30 minute period. So that means, if you go armed_away, you could be waiting anywhere between 5 minutes and 41 minutes for the lights to turn on (or off).
group.all_lights is a premade group that you don’t have to specify. It’s done by home assistant.
The group you are creating is called group.lights, not group.all lights.
(Noticed in previous post, current looks ok). Are you putting the ** comments in? Switch those to a single #. Comments in yaml are # this is a comment. *'s are not a comment and will be used in yaml.
All of your automations look correct. Even with the items I am pointing out above they should all work. So what does that mean? Well the good news is that all of your automations have 1 common condition. All of them are looking at the state of your alarm panel. None of them are firing, so first thing I would do is verify that the armed_away state is actually correct.
So, what I would do to test this instead of waiting 90000 hours between triggers is the following:
Make a new automation that fires minutely and does not have a delay. Do not use a condition at first. Once that works, add a ‘armed_away’ condition. See if it still works. Then continuously add all your conditions until it’s working.
